1 - 3 of 3 Posts
Has anyone done their own modification to the stock fender stays to accommodate a wider rear fender?
Duke,
When I went to New York and brought to GS Cycles guys the wheel, swingarm and fender stays for the 280 kit, I talked to Eric and Pete about many things. One of them was the fender stays. Pete actually did by himself the stays on his yellow "Tonga" Warrior. They looked identical to the original stays, not shaved or modified in any way. He also incorporated into stays a set of flat angled blinkers, so they looked like being part of the actual stay. The stays were cut, modified and welded. Because the stays are hollow on the inside, you will probably have to plate them...
I would recommend you to contact Eric and ask him how Pete did his stays (tell him you know Floren). He is very friendly and he will give you good tips for sure.
1 - 3 of 3 Posts
