1 - 6 of 6 Posts
I want you guys to ponder on this a while and tell me what you think. I believe I can make some shims to move the fender stays out on each side of the bike to accommodate an 11" fender.
I was thinking about purchasing a small length of PVC, Splitting it down the middle. Then cut a couple of lengths equal to the section that attaches to the frame. These would be like a shim between the stays and the frame. They would just need to be drilled for bolt clearance, spray painted black, and mounted between the stays and the frame.
Whatcha' think?
Suggest using aluminum tubing. Its easy to cut & will not crush like PCV. Available in different diameters & wall thickness.
Go here: http://www.mcmaster.com/
Type aluminum tubing in the find products box in the upper left hand corner of the home page.
Discussion Starter · #3 ·
Thanks Woody. What do you think of the idea? It should look a lot better than shimming with washers because ther wouldn't be a void between the frame and the fender stay.
I like the idea. Maybe make the shim(s) a bit longer & extend the end of the shim(s) out toward the front of the bike a bit so you have steps off the frame rail back to the fender stay.
You could also have a taper put on the end of the tubing so that instead of a step down to the frame it would transistion gradually
The fender stays are currently doweled to the bike frame and are spaced out approx 1/8" at the leading edge (beauty face)and the profile of the gap is not symmetrical.
The '04' spare fender i have measures 10 9/16"& 10 1/2" across the mounting holes, front torear respectively so there isn't that much difference with your new 11" fender.
I would procure or machine up the appropriate hollow dowels & spacers to solidly mount the fender stays to the frame.
Since thebrackets only need to move out approx 1/4" and the gapwill only be visible on the leading edge, i would scribe a filler pc made of a mat'l of your choice that is easy to work with and silicone it to the inside of the fender stay. A pc of thickblack neoprene sculptured to the gap would work too!
If you plan on doing 2-up riding you'll want the fender stays to maintain their alignment to the frame by maintaining the dowels.
Good Luck
1 - 6 of 6 Posts
