1 - 10 of 10 Posts
I called the stealer to schedule the TPS and CPS recall work, but instead he asked if I was coming in for the ignition coil recall....Ummm, whats that? He said the 1700 has a coil recall.
Could he be thinking road star, and not RS warrior? this will be #5 so far....
Diver
CPS (crank shaft position sensor) is Pick up coil Sensor.....TPS is Throttle Position Sensor. Do yourself a favor. Find a new dealership.
CPS or Pick up Coil Sensor. Same, same....to both of your postings in this topic.
quote:Originally posted by crown
I have a recall letter to replace lead wires for the pick up coil. Maybe thats what he was talking about.
Guys it's not the ignition coils, it's the Pick up Coil Sensor. It's located inside the clutch housing, so if you want to change your clutch spring, now's the time.
1 - 10 of 10 Posts
