1 - 3 of 3 Posts
Great way to haul your cruiser around, I just don't a cruiser anymore and don't need this in the garage anymore. Heres some info on it. This is the first version. This will any cruiser and Full dressers. Can be mounted in the back of a pickup truck or other haulers. Don't have any pics but can be seen anytime. Retail is $2500 plus the shipping(300-400 bucks)so save yourself about $800 an buy mine. anyone looking to start a business can use this to pick up peoples bikes and haul them to wherever the customer wants. One particular guy charges $75 just to hook up.
2000.00 or
As for trades, looking for a 4stroke dirt bike(yz,cr,rm,kx) or things that go bang are cool too.
pretty sure this is the 95" model. PICS ARE JUST EXAMPLES, TRUCK NOT INCLUDED. the lift is the part for sale or trade not the truck.
Will not ship!!!!!!
Fits into compartments or onto truck beds that are up to 39" off the ground. Needs 48" to 52" clearance from back of cab to front of trailer when trailer is turned at 90 degrees. Standard lift is 95" long. Optional 99 1/2" lift available for truck beds up to 41" off the ground.
Precision welded utilizing tooled fixtures. Made from, high quality structural steel. Black powder coated finish provides long lasting rust protection.
Simple, reliable design is easy to operate. Flip the switch and watch your motorcycle load - safely, easily.
Carriage tracks are slotted to drain water, dirt and debris.
Industrial grade nylon or stainless steel wheels and rollers. No bearings to grease or maintain.
All Weather 12v 2500 pound electric winch with integrated safety brake and 12' cable remote control switch. Winch cable is 6000 pound rated stainless steel aircraft cable(this is actually a heavy duty 4"strap). Also included is an all weather electric cable - one end plugs into a socket on the RAMPAGE, the other has 2 ring terminals that connect to the truck's battery.
Very little maintenance required - juts keep clean and inspect the winch cable before each use.
Can be installed in beds up to 39" above the ground. Maximum motorcycle weight - 1000 pounds. Optional 99 1/2" lift available for full dressers loaded into truck beds up to 41" off the ground.
1 - 3 of 3 Posts
