1 - 15 of 15 Posts
The hardware I used, was bought at my local Ace Hardware & was roughly $10.
2 - 6mm x 1.0 chrome allen bolts approximately 2" long.
2 - 1/4" ID x 3/4" long chrome spacers
2 - 1/4" chrome flat washers (omit the 6mm flat washers, they were too small to use)
Step #3, I reindexed the horn's mounting bracket so the horn would point down when installed...I removed one of the horn's assembly screws & moved the bracket one space back - counterclockwise...Reinstall the assembly screw ahead of the bracket...
Step #5, install horn assembly into starter bracket bolt holes. Tighten to spec, & reroute the horn harness over to the left side of the engine. I simply ran it under the voltage regulator, securing it into the one ratcheting clamp directly below it. I then secured any loose harnesses with zip ties.
Awesome write up. Saved this post to possibly do the same later, and the break down into different steps with pictures is great!
Sent from my SM-G935V using Tapatalk
Very nice-thanks! I noticed that there is no charcoal filter/canister on your bike. Was this removed, or is it Calif. only? Maybe I should ditch mine! It would also seem to be advantageous to have the opening of the horn facing forward, so it would be directionally louder-toward whatever you are honking at-anyway to flip the bracket so it points forward? Again, nice job!
I like the sounds of that idea too. I have no idea of that would be possible but something to keep in mind when attempting something similar to this myself
Discussion Starter #15
Thanks!!! It's an old write-up I did some years back, but it's still very useful for more and more new Warrior owners. Canister is Cali specific. I pointed it down so it won't fill with water in the event of riding in the rain. Water takes a horn out pretty quick, lol.
1 - 15 of 15 Posts
