381 - 391 of 391 Posts
This is going to attract some attention.
What amount of fuel do you think it will hold?
Many thanks for sharing. I love those reports with pictures.
I'll follow for sure ......
Tank will be very high, so gauges cannot be seen anymore ?
Probably you plan to relocate into the tank ?
Good luck with this, looks very professional. Keen to see more...... 🙏
Ok I’m probably missing something in the translation. I guess you had an accident so your warrior was damaged, I get that part. However what is the cage for, is it for a new designed tank?? 😎😎🐝
Discussion Starter #384
I guess about 2.5 to 3 gallons. I don't mind it, because its going to be a cafe racer and not a cruiser1
Discussion Starter #385
Thanks for following along! I removed the speedo, because I never liked its location. The tach is still there, and very visible!
Discussion Starter #386
I never had an accident with my Warrior. I bought it just to turn it into a cafe racer many years ago!
This is the shape of the new tank, and I will have to shape aluminum sheet metal to fit to make my new tank.
I had an accident with my 08 Raider in 2012, and turned it into a bobber after that.
It has over 155k miles on it, and is still running strong!
249542
Cool, sounds like a plan. Keep us in the loop !
Like the look of the Raider, the tank dish and the color are awesome. Never used a suicide shifter, great stuff though.
If i can ride like this and still see the speedo in the stock location.. this tank will be no prob at alll
249543
PeterSik: makes sense, thanks.
When using my tank bag, I see it as well when leaning a bit forward.
Might be the position on a cafe racer anyway. Should be fine then (y)
Ahhh ok, deceptive .. to me it looked like it was going to be a lot larger than stock tank.
