Need input and suggestions
662 views 4 replies 4 participants last post by  jspencer
I'm in the process of customizing my warrior. I removed the tank and want to install a BAK with velocity stacks (as seen on this board). Now that I have the tank off what do I need to do to remove the stock plastic box? I want to remove the whole thing but want to make sure I don't damage something in the process.
Thanks,
Todd
#2 ·
All the info you'll need to install the BAK can be found here..
http://www.rswarrior.com/forums/topic.asp?TOPIC_ID=5342
Other than that most, if not all, velocity stacks you'll find on this site, other than Stage IV kits, are for show..
Good luck, and don't be afraid to search the forums for useful mod info. There's a ton of it there, just about everything you can think of is available in some form or fashion...
