Need major help
2.3K views 33 replies 12 participants last post by  JusticeWarrior
I attempted wiring up a remote start today and couldn't get it to work. Now I get a diagnostic code 19, the bike will not start unless I pull the clutch in and it doesn't recognize when it's in gear. What did I screw up now? Please help!!!
#5 ·
When I go with an alarm I'd like to have remote start. Course I'd wire it to not start unless in neutral. Now I go outside -- fire the bike --g/f locks door cause she thinks I am going, and switches part of brain off that hears cussing and pounding on garage door--shut bike off-- unlock door-- start bike up -- go in to get jacket helmet and gloves-- girlfriends brain then kicks in and has to ask me to "do something for her before I go".
New scenario
hit garage door remote -- hit remote start - put on jacket gloves helmet -- leave
#7 ·
O.K. This is for you electrical experts out there.
These problem arose while attempting to install a remote start. I was utlizing with the four wires from the main key switch and the starter button wire. After being unsuccesful at the install I removed the remote start, reconnected the factory wires and found the following problems:
While in neutral the bike will crank but not start during which it reads code 19. When I pull the clutch in the code disappears and the bike will start, but as soon as I release it the bike dies.
Another problem I found is the neutral light works if the sidestand is down, however when I raise the sidestand the neutral light illuminates in both neutral and in gear.
I checked the main switch, cut off switch, starter switch, clutch switch, and the sidestand switch which are all o.k.
I currently have the bike drivable by jumping the clutch switch and disconnecting the neutral switch however the bike will not start with the stand down and shows nuetral while in gear.
I know thats alot but any help would be appreciated as I'm not getting anywhere trying to decipher the electrical schematics from the manual.
Thanks
#14 ·
I've been thinking about this all morning. It sounds like you have the Clutch lever wired to the Kick stand circut. You have the Kick stand wired to the neutral indicator circut, and the neutral indicator wired to the clutch circut. I would start by disconnecting those three wires. Hook up one circut at a time to make sure you have it going to the right place. Good luck.
#16 ·
according to my schematic the clutch sw,neutral sw, and sidestand sw are all on the same wire going to the ecu. Looks like it needs to see a ground there -- how it tells the 3 apart I haven't figured out yet.
Also -- man this is about the worst wiring diagram I have ever seen sheesh!!!
#18 ·
I'm going to try to check the relay this week.
I know I rewired the ignition correctly which is why I believe there is a short somewhere but what is more likely to be damaged, the relay or computer. Thanks again for all your comments.
This started out as an alarm project but since the alarm also came with a remote start I decided why not...guess I'll think twice next time before I start wiring using the trial and error method of installing things.
