21 - 28 of 28 Posts
The zero map is specific to the version of power commander you have. Go to the menu and Create a new map. Then save it without any changes. Name it MyZeroMap. That is the zero map for your version power commander.
A map by email is most often not going to be what you need considering there are 4 versions of the PC3 in the USA alone.
"The zero map is specific to the version of power commander you have.
Name it "MyZeroMap"
That is the zero map for your version power commander."
Ah ok thank you. Yeah because ever time I opened the software up, thr map was just full of x and I couldn't change any of the settings. So by creating a new map, it sets everything to "0" allowing you to come back and change settings.
Is that right ?
Correct. So if you choose to create a new map it starts you off with a blank map.
Ok, I tryed this last night. I opened up the software. It loaded. The map was full of "x". I didn't have an option to create a new map. There no tab for that anywhere. All I get is load map, save map. I've checked every tab at top of my screen. I'm usually pretty good with computers. But I couldn't find anything that would allow me to create a new map.
21 - 28 of 28 Posts
