Post pictures.
Also look at the 'sprung a fuel leak' thread to see where troubles have occurred in the past.
Updated April 4th 2014: It seems another large number of fuel leaks have occurred since the last update in September 2012. I expect we should be wondering why Yamaha has not done a recall to cover the 2002 left side dry-break, and also the fuel tank outlet Filter Assembly for the...
www.rswarrior.com
The fuel flow: the top (main) tank feeds into the underseat (auxiliary) tank that has the fuel pump inside it. The auxiliary tank and the hoses are always full when there is any fuel in the top tank.
The stock dry breaks have twin valves to stop fuel flow from either half. You get a very small amount of fuel escaping. But no real flow.
You will need to ride the bike until the top tank is empty. Does your low-fuel light work? If yes, ride until the low fuel light illuminates. Then separate both dry breaks and no fuel will flow out.
Here's plenty of fuel system info to orient:
This area is a storehouse for General Warrior 'Maintenance & Repair' Help Files. 1. This Table of Contents. 2. Stock Turn Signal Bulbs by Model Year, plus UK notes. Replacing the Flasher. 3. Stock Warrior Tool Kits, 2002, 2003-2005, and 2006+, Plus Other Tools. 4. Changing the Motor Oil and Oil...
www.rswarrior.com
Also, in case helpful, if its been sitting in storage a long time:
1.
A Question Regarding Warrior OEM Dry Breaks. When the OEM dry breaks come off the bike and sit on a shelf awhile, has anyone noticed internal debris forming? I don't have pics but I pulled-out some of my spares today to do a comparo to a spare under-seat dry break assembly I just bought...
www.rswarrior.com
2.
A friend of mine just got an 06 Warrior that had been sitting for 2.5 years. We put in a new battery, oil and plugs and fired right up. He rode it for about 100 miles, filled up with fuel, started up and rode about 10 miles and then started sputtering under throttle. Bike will still get up to...
www.rswarrior.com
Stock dry breaks (never use a 2002 dry break):
Fuel Tank - Dry Break '03 -'10 - Underseat:
Female 5PX-24305-00-00
Male 5PX-24304-11-00
Fuel Tank - Dry Break '03 -'10 - Left Side:
Male 5PX-24304-01-00
About Aftermarket Dry Breaks:
NOTE: with aftermarket dry breaks you must be certain they have valves in both halves. Also you must hold down the button when separating the halves AND when reconnecting the halves or the latch mechanism inside will nick the o-rings and create a fuel leak.
This area is a storehouse for Beginner's Modification help screens. 1. This Table of Contents. 2. Problems After VBAK/BAK or Ignition Coil Relocation. 3. Selecting and Installing Aftermarket Fuel Dry Breaks. 4. Turn Signal Fast-Flash and Click of Death (COD) Solutions. 5. AIS Bracket...
www.rswarrior.com
