1 - 7 of 7 Posts
I have on my bike currently a Gates belt I bought some years ago -
BDL PC - 130 - 118 212A
I saw a Harley belt, brand new, 130 - 118 so I bought it cheap, now its here, the code on it actually says
BDL PCC - 130 - 118 128F
I don't know what these codes mean or if neither of them is the right one - I'm having trouble getting to the bottom of it, I just thought if its 130 - 118 its near enough, they all look the same to me! I just hope its safe - any ideas, advice, comments?
The Belt is Fine
The PC designator is a Polymer belt only and what I have on my ride.
The PCC designator is a stronger belt - Polymer & Carbon
I suspect the 4-trailing #'s are a date stamp or batch # ? Mine is 137V
Suggest you send an email to them for this info :)
Here's a link: Belt Drives, LTD.
  • BDL = Belt Drives, LTD
  • PCC = Mfg'd by Gates Rubber with polyurethane with carbon cord
  • 130 = No. of Teeth
  • 118 = 1 1/8" (1.125") Wide
  • 14mm pitch of course :)
My current Belt
Belt Drives Ltd - Mfg by Gates _ 1-1/2" wide - 14mm pitch - 130 teeth
Phat Performance sells this as a Gates HTD Poly Chain Rear Drive Belt under Part GATES-HTD 42616
The belt is tagged w/ Drag Specialty P/N DS-197099, Vendor # PC-130 & Description: 130T 14mm Belt #40017-94
Thats quite reassuring, thanks Alan, I measure the pitch at 14mm and it seems to be about the same length as my old snapped one - so its all looking quite good, Bargain even!
I was used BDL PC-130-118 too, but very short time(had undiagnosed CPS problem).
Before installing I had visual compared new origial belt with BDL PC-130-118. It was almoust the same but exept color. BDL was more bright color :rolleyes:
Uh oh! I busted one when a stone got hooked into it falling off in snow -
the one on there now has done about 40+k, and twangs a bit sometimes, so I assume its stretched!
My friend using this belt. Just about last 10000km but he ride aggressive and belt still working.
I think this belt and original are the same but with different marks.
Add some photos:
1 - 7 of 7 Posts
