1 - 7 of 7 Posts
hello to everyone. Sorry about the new guy stuff but I have been on crotch rockets. Here is my question, if you change the pipe on these bikes do you have to have the map re-done? I am really confused about this and the air box things? If someone could shed some light on this it would be great.
Thanks
Stephen
yes it is recommended that you change the map. Just to make sure you dont run to rich or lean I am sure others will chime in soon
welcome to the 4-m , if you re-pipe you can bump up the numbers on the ecu this is done through the instrument panel you can do a search here on the site for more info on that, as for the air box.. a lot of us ( myself included ) remove the stock air box and add a BAK ( big air kit ) which is basically a couple k&n filters and also block off the air injection system ( AIS ). check with woody ( churchkey) about the BAK he sells.. i have it and it works great.. you will find a lot of help here from these guys and also a lot of mods that you can do to really personalize your warrior!!! hope this sheds some light. bigjohnson
bigjohnson has it right, but many of us also have a Power Commander III. This is the mod that will need remapped when you add performance mods such as pipes and air kits (VBAK). A properly mapped PCIII delivers the best fuel/air mix.
You don't have to change the map. I rode mine ~30,000 miles with the D&D slip-on before I got it mapped. I wouldn't necessarily recommend doing that, but it's ok as long as you're not either too rich or too lean.
1 - 7 of 7 Posts
