New never installed (bought as spares)
USPS at cost.
Box of 4.
Part Number: BPR7EIX
Stock Number: 4055
Heat Range: 7
Thread Size: 14mm
When installing high output ignition coils like DC2-1's you need secondary spark plug wires with boots both ends. The Warrior stock spark plugs are threaded-stud terminals. It's possible to buy screw-on terminal ends for your stock spark plugs. However the DC2-1 type high output coils play very well with Iridium plugs.
These plugs fit the Vstar1100 series (shaft drive series) check your specific. It also happens to be the perfect fit for Warriors upgraded to high output coils. Handy.
These don't need to be gapped. Lots of conversations say otherwise but my decade+ experience shows not, as does other member reports. But if you want to gap them read-up on the special procedure and notice which style of gap tool works on fine-wire/Iridium plugs.
