quote:Originally posted by shivaman
quote:Originally posted by Mic182
if u look in the manual under Engine break in it says... 0-600 miles avoid prolonged operation above 2500 rpm, 600-1000 miles avoid prolonged operation above 3500 rpm, after 1000 miles go nutz!!!!... I went along with that for my break in and the bike is running amazing, and change the oil at 600 miles and transfer case fluid also...
and welcome to the forum...
Thanks but I have borken in my last two motorcycles using this guys method and I really believe in it. Check it out!
The MotoMan
http://www.mototuneusa.com/break_in_secrets.htm
Perfect, I was going to give you that site. That's the way to go. We've had members with glazed cylinders from the easy break in method.
Many of us have used the moto method, I'm a BIG believer in it. Just be sure the engine is warmed up before you hit it hard.
Search for the owners manual on here and you should be able to find a PDF to download. (the service manual is also available for download and VERY helpful) The oil change is a little different than most bikes. There are 2 plugs and it's easy to get the wrong bolt for one of them. Also, after you drain it and change the filter, Put in about 2.5 quarts, start the bike for about 10 seconds, shut it off and add 2.5 more. 5 total will give you the perfect fill. (the oil must be hot and the bike upright to check it....go for a decent length ride before checking your oil otherwise it will appear low and you WILL overfill it)
I would also recommend changing the transfer case fluid after about 100 miles. There was a lot of silver in mine when I did it. Bummer is you have to take the pipe off to change it.
I'm also a firm believer in not using synthetic oils until about 3-5K miles. I stuck with Yamahalube and then went to Mobil 1 v Twin and mobil 1 gear oil in the transfer case at about 3500 miles. There is a lot of debate on oil here, you should find more than you want to read if you use the search button.
Congrats, I know you can't wait until you get it home. Have a blast, be safe.
