Re: no fire on the spark plugs
Never mind, I see a couple new posts since I last checked in here . . .
Do you know how to adjust your clutch? Once you're positive the clutch is adjusted right,be sure both air filtersare clean, and all 4 spark plus are clean and gapped. Then keep it running long enough to get warm, then up the idle rpm's a hint. If it stays running then pull in the clutch lever and drop it into gear. If it still stays running you're headed in the right direction. If not, post up the details of what happens along the way so we know what's going on and maybe can help.
BTW your headlight should come on after the engine starts . . . is that how yours is working too?
