1 - 3 of 3 Posts
Let's find out. Need info.
What bike do you have, are you the first owner?
Do you know what mods it has? If not, can you post pictures of all 4 views of the bike plus a couple under the rider seat?
Is the check engine light illuminated?
Do you know how to check for error codes at shut-down (use the handlebar off switch and look in the gauge display for numbers).
Do you have an e-copy of the service manual yet, and do you know how to look in ECU History for error codes?
Also just to get you started, when did this symptom first appear and did you repair or modify anything beforehand?
Whew. Its easier than it sounds. Let us know about these things and we can get the hunt going.
Unfortunately like Arizona said we need WAY more info before we start forum assessing. Think of it like when you first go to the doctors and fill out 16 sheets of your physical history.
For all we know it could be that your idle is set to low.
1 - 3 of 3 Posts
