We've all been there brother! Maybe the cable isn't disengaging the clutch all the way. Plus when the Warrior sits awhile, the wet clutch gets a little sticky. Sometimes it takes a lot to break it free. Best defense is to ride often, but if you can't ride in winter then maybewhen you warm it up every couple weeksbe sure to use the clutch to jog the bike forward, then roll it back, you know, a couple times to work the clutch. Plus keep the ball-ends of the clutch cable lubed (I just use WD40 it works fine) so you don't stretch it out too much. All those big cubes need to get out on the road and run, right!
