1 - 5 of 5 Posts
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
I recently installed a BAK. It has been on the
bike a few months now. About a month ago I noticed oil on the top of the
rear cylinder. I thought the rocker box
cover was leaking. I pulled the tank and
noticed that the breather for the rear cylinder was saturated with oil and was
leaking out. I removed the filter from
the hose and cleaned it. I took the easy
way out to try to fix the problem and purchased a PCV valve from Autozone. I installed
it inline between the filter and elbow that sticks up on the rocker box. It seemed to work fine until just the other
day I noticed it was back.
Any one else had this problem and figured out a fix?
Thanks for the help.
J-man
Some on hereextend that hose on out and down by the swingarm just in front of the rear tire. I put some leftover unifilter over mine and clean it every 1000 miles or so.
I would get a crank vent from E.T.performance, it should all but fix your problem.
jgreen53 ... my solution shown below
AlanH said:
Thu, Jan 10 2008 3:53 PM
vent lines, oil leak?
quote:
Originally posted by bruce59
That one I am familiar with and I use a longer hose (fuel line I believe) and I route it down and out beneath and in front of the swingarm.
Yup here's mine from an earlier post: Smelling Oil: http://www.rswarrior.com/forums/topic.asp?TOPIC_ID=50137
I have a krank vent on mine with a breather filter at the end of the hose, near the rear swing arm.
1 - 5 of 5 Posts
