1 - 2 of 2 Posts
Ok, so I got a bunch of pics and measurements.
The Older 3323 (Black label), Current newer 3323 (White label) and just to add in since I had it a 3323ST (White label)(Not sure about the factory specs on the 3323ST yet.)
(Maybe we should start a new thread on this filter and a usable fix ?)
I took pics of these areas-
1 Box and label comparison
2 Filter height comparison
3 Top comparison
4 Center face comparison
5 Inside comparison
1 Box and label comparison-
2 Filter height comparison-
3 Top comparison-
4 Center face comparison-
5 Inside comparison -
I took measurements with pics of these areas-
1 Base diameter
2 Height with the rubber gasket
3 Height without the rubber gasket
4 Height of the rubber gaskets
5 Thickness of the rubber gaskets
6 Depth of the gasket seats on the filters
7 Depth of the inside of the filters
8 Depth of the threaded flange area just outside the threads to flush with rubber gasket
1 Base diameter -
2 Height with the rubber gasket-
3 Height without the rubber gasket-
4 Height of the rubber gaskets -
6 Depth of the gasket seats on the filters-
8 Depth of the threaded flange area just outside the threads to flush with rubber gasket-
Rudy Jeremias (rij1)
Discussion Starter #2 (Edited)
Here's a fix for The leaking oil filter for the 3300 and 3323 oil filter with the White label (currentlyon the market)or others filter brands that leak.
There's a few fixes for this issue and unfortunately it affects 02' - 05' due to the Union Bolt Nipple having a thick Hex fitting that the filter base rim contacts leaving a small gap that leaks oil through.
Due to filter changes this can be any issue with multiple brand filters.
One modifies the filter and the other replaces the Oil filter adapter Union Bolt.
1st Fix per filter.
This includes Bosch 3300 (White labled), Bosch 3323( White labeled)and other filters that leak.
1 - 2 of 2 Posts
