1 - 4 of 4 Posts
Oh there’s a small oil for on the clutch side of the motor that has a wire hooked to it that seems to be broken and there’s oil dripping from it it has like a nut on it I was wondering cannot be replaced with a new one
The only wire that exits the Clutch Housing engine case is the CPS (crankshaft position sensor) 2-wire harness that has a molded rubber grommet integral to the component assembly.
If either of these wires are completely severed the engine will not start and a fault code will appear on the Tachometer display and IF the grommet is Not properly installed with sealant it's possible that a small engine oil leak will appear at the junction!
Enclosing jpeg's of the component.
1 - 4 of 4 Posts
