1 - 8 of 8 Posts
Look like warrior jugs to me
14 warrior cylinders on a single engine..... Crank her up, let's hear that bad boy roar.
I remember this motor.
It was talked about way back and finished a couple years ago.
Yes is a warrior based motor haha.
Its really a bad boy. I'd think it would make more power.
Russell Sutton’s 14 Cylinder Radial Engine*
Engine info:Twin Row Fourteen Cylinder Turbocharged Radial
Top ends XV 1700 Yamaha warrior from mid 2000's sourced from the States
Pushrod four valve heads
Bore and stroke - 97 X 113 mm
True displacement is 11.7 litres.*
Master Rods, Link Rods, Crank and Cam Plates by Ian Drysdale (Drysdale
Motorcycle Company)*
Turbocharger - HX55 13 litre Cummins / Volvo type.
Intercooler - Dual pass 700 x500 mm*
Boost - 12Lbs on standard 8.3:1 compression Pistons
Standard Yamaha XV pistons
Power output. 600Hp /1170 Ft LbsTorque @2700 RPM (Prop limited)
Other Parts:
BA falcon Oil pumpLS1 throttle body, roller lifters and ignition coils Cam plate Ratio 1/8th speed forward with four lobes each track
Prop - A three blade whirlwind for Airboat which will absorb up to 700Hp. (Direct Drive) Intended use flat bottom Airboat (swamp boat)
1 - 8 of 8 Posts
