1 - 5 of 5 Posts
Yes this is a blink rate question and no it isn't the same as the hundred other blink rate questions.
I've just replaced my front and rear stock indicators for the Kuryakyn LED mini bullets which flashed as fast as expected after reading several posts on the subject.
So I then installed a Kuryakyn 4amp load equaliser in the headlight for the front and another under the seat where the rear harness connects to the main harness. Start the bike and blink rate is close enough to normal, but then I catch 2 or 3 fast blinks.
So now I'm getting about 5 or 6 slow flashes then 2 or 3 fast flashes? and have no idea what to do next. I asume both load equalizers are working as they get both start to warm after a minute or so of flashing. And I don't think it's a bad connection as the lights blink at the right times etc. Any ideas?????
I have the Kuryakyn LED bullets as well. I had to put the load EQ on the brake circuit to solve my problems. (I think it was the yellow wire in the bike harness)
might give it a try
Do front and rear signals act the same way?
1 - 5 of 5 Posts
