PCIII help
720 views 5 replies 6 participants last post by  jspencer
I am attempting to map my PCIII as we speak. I cant figure out if the thing is mapped or what?? The instructions are very vague. Does the PCIII do anything or should I get some sort of message on my computer verifying that the map I installed is loaded? Any suggestions???
#4 ·
When uploading a new map you should see messages on the bottom of the screen indicating that the computer is verifying and uploading the new table. Then if you want to be sure what is in the PC-III you can just do a "get map" and see if it does indeed have what you uploaded.
The documentation on their web site is actually quite extensive, I thought installing the PC-III was simple and clear. Take a look at the following post and follow the links to powercommander.com:
http://www.rswarrior.com/forums/topic.asp?TOPIC_ID=7403
#6 ·
Dice is correct I would have the bike running. You can download the zero map for the Warrior from Dynojet. It has nothing but zeros, load it into your coputer setup console but instead of mapping it to the bike, choose get map from the bike. You can then print it . Then load the map you wanted to map to the bike into the console. Check the numbers if they are the same the map is on the PCIII
