PCIII installation?
654 views 6 replies 7 participants last post by  desertwarrior
I'm trying to get an idea how to hook this before I get it. I'm looking at the instructions on web site, and the order doesn't make sense. The labeling numbers and letters are all over the place. For instance, the picture labeled "F" isn't in order. Any help? Heres a link to the instructions:http://www.powercommander.com/maps/install/I403-211.pdf
#2 ·
http://www.rswarrior.com/forums/topic.asp?TOPIC_ID=7738
It's pretty straightforward. One wire to ground - attach it directly onto the bolt that the battery is grounded to. Run the remaining wires up the right side under the tank, down behind the air box (or whatever you have there) and the PCIII's plugs directly mate to the injector plugs. Unplug the (white) injector plugs and mate each of the PCIII plugs to these (don't forget to silicone!!!). Use the vampire tap onto one of the wires (yellow or gray, can't remember which but will verify when I get home). I keep my PCIII under the seat, on the left side forward - in that little alcove above to the left of the tank drybreak.
#3 ·
1 remove the seat
2 yank the tank
3 pull the shield (right side air breather)
4 install pc3 under seat fish wires through to the shield install vampire clip plug in the plugs then install shield
5 ground wire on pc3 (need good ground)
it took me 3 minutes i couldnt believe it works great
#5 ·
Watch the injector plugs. Mine was broke and I had to drill a pieace of plastic out of it. It takes more then 3 mins but it's pretty simple. Directions are okay. Your right they do "seem" to jump around but it's easy to figure out.
