1 - 6 of 6 Posts
when i get the tps recall done will it effect my power commander? thanks.
Getting TPS done next week and I spoke to the guys that did my cutom map today. They said that they would probably have to reset something unless the mechanic got the new sensor in exactly the right place. It did not sound like it was going to be a big problem.
After the TPS recall work is done, it has to be re-synced to the PC111. Simple process but be sure to tell the Dealer it has to be done since they may not know. It's a simple process that has been covered in a previous post so a search should find it.
all you have to do is set the throttle wide open and closed settings on the pcIII, through you pcIII software. All else should be good to go.
what fcwarrior said....need to be sure to hook up the pcIII and set throttle position to 0 at idle. PCIII web site has the how too's in tutorial #10 as I recall. This is after the dealer does the tps recall.
1 - 6 of 6 Posts
