It is very easy to install this software into the PCIII and it has a noticable effect. The throttle response was direct before and it is even more direct now. It is also very easy to make adjustments as long as you have the computer nearby. For fun I adjusted the sensitivity up to 100 (max) to see what happened and you could hear the motor struggling as the mix became a "little" too rich. Managed to shoot som blue flames as well. For those who want to avoid popping set the sensitivity very low. Personally I don't mind some popping and set sensitivity to 80 and used the other values suggested by DynoJet for street riders.
Did the install and adjustments with the motor running to power the unit and not the 9V battery.
