1 - 3 of 3 Posts
Hello All,
I already have the Baron lowering kit, I want it lower. Is it toolow to add the PCS kit with it? Anyone done it?
Thanks
Lots of options rather than combining two:
Suspension - Air Ride: http://rswarrior.com/forums/p/16834/274689.aspx
Suspension - Air Ride: http://rswarrior.com/forums/p/26983/388623.aspx
Suspension - Air Ride - PSI Gauge: http://rswarrior.com/forums/t/116567.aspx
Suspension - Tricky Air - Tire Life: http://rswarrior.com/forums/t/113191.aspx
Suspension - Spring - Rear - Stiffer: http://www.ground-control-store.com/products/description.php/II=367
Suspension - Spring - Rear - Eibach 1000: http://rswarrior.com/forums/t/29316.aspx
Suspension - Spring - Rear - Raising Methods: http://rswarrior.com/forums/t/106308.aspx
Suspension - Spring - Rear - Raising Methods: http://rswarrior.com/forums/t/106293.aspx
Suspension - Spring - Rear - Lowering Links: http://rswarrior.com/forums/t/29316.aspx
Suspension - Spring - Rear - Lowering Methods: http://rswarrior.com/forums/t/109605.aspx
1 - 3 of 3 Posts
