1 - 10 of 10 Posts
I was thinking of putting in a PCS 1000lb spring in and I was curious as to know if it would slightly lower the bike with the flip and grind already done? Also what are some of the benefits of the spring? Is it more for comfort or performance? thanx in advance
no, that spring should not lower it.. i did a progressive spring on my 02 and it did lower it an additional 1/2 inch but you can adjust for this with the preload adjustment on the shock. hope this helps. big johnson
I have a 100lb spring wating to be installed.. If I put it on with the bike already lowered.... dunno if I'll like it at all.. too much rubbin...
Yeah... I had a bunch of crap sitting on the shelf in the garage taht was never used on my 02.. opening boxes revealed all sorts of hidden treasures.. /emoticons/emotion-1.gif
Will get around to installing the spring one of these days..
1 - 10 of 10 Posts
