1 - 6 of 6 Posts
Curious why there is no section specific to PCV maps? I went to the Dynojet site and didn't see anything for HC pistons....anyone have a map for something similar?
02
Rineharts
HC pistons
Churchkey VBAK
AIS blockoff plates
Thanks!
You don't need autotune, that's just how I am mapping it perfectly. I'll take it off when I'm done with my new HC piston map.
The badger map at that link will do you great, I don't remember if it's a pc3 or pc5 map, but you can adjust it accordingly
The only big difference is that a PC3 map is set up for 500rpm increments. PCV is 250rpm increments. When you import the map (the badgerHC is a PC3 map BTW, I check) it'll open proper for you automatically. Just instead of clicking open map, you click import PC3 map. Then I'd save it as a normal PCV map.
1 - 6 of 6 Posts
