hey
guys, i need help solving a problem on a 2003 warrior that has a
V&H big shots pipe. i can't seem to get the popping sound or you
may say the shotgun sound when you let the throttle out. i remove the
smog pump and plug the AIS and replace the O ring seal on the exahust.
i also took the bike at DYNO SHOP to have it tuned . took it back
about 5 to 6 times to re-adjust the caliber on the spec but popping
won't go away. it did help a bit but the shotgun sound are still there
but not as bad as it use to be.would kindly appreciate if someone could
help some input to solving the problem. thanks in advance.
P.S. bike has 6,600 miles
