21 - 40 of 41 Posts
Here's a terrible sketch showing the dimensions of the Warrior's front and rear rotor bolts, and the sealing washers for the fuel injectors (service manual page 6-40) that are recommended to be replaced each time the injectors are removed. I'm not sure replacement is necessary but here it is anyway.
I know I should sit down and make a better sketch, but it'll have to wait.
These are for all model year Warriors. In these three specific cases, the part number differences were related to Yamaha re-organizing some of its part numbers. I presume the 2010 Canada models, and the 2011 New Zealand model, use the same bits.
I'm feeling certain there's no other place to buy the rotor bolts, they 99.999% are purpose-built by Yamaha.
The fuel injector's aluminum sealing gaskets might be found elsewhere but I haven't found them yet. They look like flat washers but are not.
I measured with a digital caliper, but let's say that all dimensions are approximate anyway.
Sorry for the delay on this, and hope it helps a little.
Discussion Starter #22
excellent - have a brownie point - i'll let you off the nervous drawing :D
now when i give out a brownie point it's yours to keep and hard to loose...now remember that.....important information below
it's not however how it goes, when the love of ya life hands one out!!
HUGE Thanks to AZWarrior & Tomba. I can't even imagine the time it took to organize all this just to make things easier for everyone else. Best site ever!!!
I noticed the link under "Clutch-Redhorse" is broken. I stumbled across it researching clutch info. Here is the link.
http://img485.imageshack.us/slidesho...054461ef2.smil
If that doesn't work, here is the thread I found it in. See post #16
http://www.rswarrior.com/forums/13-technical-discussion/161789-barnett-spring-conversion-clutch-kit-sr-2-a-2.html
Thanks
Discussion Starter #29
S&S X3N 128T Belt for 31/65 -- 106-0358 ( 1.125 width )
we [as in arizona warrior and i ] wondered what pulley sizes you'd be planning to use with this belt ?...do you have any more info we can record for posterity :D
i try to finished to installed a fi controler from dynatek and at the step 7 the instruction told me this:locate the yellow wire. using the supplied wire tap, tap into that wire.connect the grey wire from the fi controller harness on this connector.so when i chec the pics on the instructioni think is a mixte up with 2 wires. or conect the yellow on the grey or the grey on the yellow wire what is the solution? thank
21 - 40 of 41 Posts
