PROBLEMS WITH LEGENDS CONTROLS
1 reading
1.5K views 13 replies 8 participants last post by  COOP
HAS ANYONE HAD PROBLEMS WITH THE WAY THE BIKE SHIFTS GEARS AFTER INSTALLING THE LEGENDS FORWARD CONTROLS? MY BIKE ONLY SHIFTS INTO CERTAIN GEARS AT CERTAIN TIMES AFTER INSTALLING THESE CONTROLS. IT LOOKS LIKE THE SHIFT LINKAGE IS IN THE WRONG POSITION.I HAVE CHECKED & TIGHTENED EVERYTHING OVER AND OVER AND STILL NO LUCK. IT SEEMS TO ME LIKE IT IS MAINLY HAVING PROBLEMS GETTING IN AND OUT OF FIFTH GEAR.
#4 ·
Sorry about the caps. I'm kinda new to this sort of thing.Spudly I just put the controls on last night.The controls seem to work fine most of the time until I get to 5th gear and then its like the trans. locks up.I will try and call phat performance today and maybe they can help me out.I will also try to adjust the lever down some more tonight and see what happens.I also noticed the bolts are hard to start in the bolt holes.I even had to re-tap the hole for the shift rod bolt to get it started.I figured this had something to do with the chroming process.
#11 ·
I was trying to shift it(with bike off and parked) through all the gears before riding it to see if it was working correctly.Gave up on figuring it out and went out to see if it would shift with the bike moving and it works fine while riding but then when I come to a complete stop I still have alot more difficulty getting into neutral than with the stock setup.
#13 ·
Can you post a picture of your shift linkage setup? The way you adjust your linkage can have an affect on the leverage or you may have something in a bind. I've got the Legends on mine and it shifts very easy and smooth. When I stop in 1st gear, a simple and easy click on the shifter will bump it right into neutral with no hunting.
#14 ·
Wolfhound,I don't own a digital camera or scanner so I can't post any pics but I checked out some of the pics of other peoples and mine looks the same.The only time I really notice it is when I am on a slight incline.I will try to adjust the linkage and see if that helps it any.
