Here is a simple kit that retains your stock decompression mechanism, keeps your idle at about 700rpm, cam is drop in, no machining the cases for clearance, and will give you enough so that V-Rod gets a good look at your taillight. The hp and tq ratings are conservative at 105hp and 125ftlbs at the rear wheel. If you want more, give me a call and we can discuss some more radical mods. Here is the pricing for that kit. Please feel free to give me a call or email me. A Dynojet 250 dyno, with the tuning link is the best bet to get the most of your pc3.
Here are current prices on what we offer: Vance & Hines ProPipe=$449
PC3=$299
95mm or 100mm Pistons=$325
100mm Big Bore Kit (includes pistons, base, and head gaskets)=$795
Big Bore kit uses your cylinders
Cam Kit (includes cams,hard face lifters,
and adj. titanium push rods) =$795
with your old cams for exchange.
High Lift Spring Kit w/titanium retainers=$795
Heads with big valves fully ported=$1030 uses your heads
Optional: Billet Push Rod Tubes= $192.00
(These are two-piece collapsible tubes, makes push rod adjustment a breeze.)
Also our high flow air filter kits will be ready in about 2-3 weeks.
Thanks David
David Brown
Patrick Racing Inc
Home of the Worlds Fastest WARRIOR!
1-714-554-RACE
[email protected]
