pulling the plug on it!!!
1.1K views 10 replies 6 participants last post by  Twisted
Has anybody have an easy way to pull the spark plugs on this w/o rmoving the tank. I would like to check my plugs more often, for the ECU adjustments, but it is a royal pain in the arse to do. i just can't find the right tool to pull the plugs without removing the tank each time!!!!
WELL???[/emoticons/emotion-2.gif]
#2 ·
No need to check all the plugs, I tune by reading the left side only. If I happen to have the tank off I'll check the right sides but they will read the same as the left ones. Thats the way it is on my bike.
#3 ·
well the reason i ask about the front one is that my ecu setting are so different between the two. there has to be an easier way!! Or maybe not. If i could only find that fine tooth ratchet, mabe a 1/4'" ratchet would work if i can somehow mack a thin wall socket that will fit...
#4 ·
I have been trying to do a search on the ECU thing and keep geting 1001 result, but non related. my original settings are c01= -5 co2= -1. I have no idea where to start from!? they are so differen, why? So many questions!!! I saw somwhere about starting out a +3 on both, and this is why i would like a quicker way to check front plug. Is there that much of a difference between the two cylinders or is it just crap to begin with(the co settings from factory)?
Actually, I probably shouldn't be checking it now anyways. It is only 38degrees out where i am at in mich. not my normal riding temp. 65 - 90 degrees is more like normal.
It isn't that the bike didn't run good a those setting, actually it ran very well, but i thought it was a bit on the lean side, then again, that was probably because it was only in the upper 50's.
But, i would like to fine tune it and figure out if a 4 point difference between the two cyliders is necesary or if it was just some number they slaped in there!!
#6 ·
Good God, why 11? what kind of mods do you have?
I think that I am just going to have to play around with it a bunch. I kept the ratio the same but up 3 points and it definally sounded diferent, but not as good. I am just going to have to wait til it warms up to be sure that isn't plying a big part in it. I am sure that it is running leander than a few days ago because of the temp..
why is everyone putting it to the same # for each cylinder, and a better question, why is Yamaha setting them so different?
#8 ·
I guess your talking about any of the plugs. There's a plug socket in your tool kit, install it on the plug & use an end wrench on top of it. No need to pull the tank to check the left side plugs.
