Quelling the Controversy: Nikasil vs. Cast Iron
36K views 46 replies 23 participants last post by  stallker
I know there has been almost rampant discussion about using cast iron cylinder liners vs. the Nikasil coating process in the Big Bore kits. [/emoticons/emotion-1.gif]
In my research, I've read a fair amount on the two processes as well as a number of forums and engine builder web sites. I found the following article to be very good in comparing the two processes and thought it might be instructive for those of you trying to decide among the various performance alternatives, Big Bore kits being among them.
I have edited some parts of the article to make it more concise and eliviate some text that does not add to our education needs at RSWarrior.com
I hope this information proves helpful to the membership and does NOT become a thread for personal attacks or arguments. [8D]
Thanks,
Gary
Source: Ward's Auto World, Apr 1, 1999 http://waw.wardsauto.com/ar/auto_boring_trutheverybodys_ideas/
"Wow. Little did we know what a fire-storm we'd start with a seemingly innocuous mention of aluminum engine cylinder-bore treatment alternatives in last September's materials issue (see WAW - Sept. '98, p.61).
There were plenty of letters and calls to point out we'd muffed our facts regarding the Nikasil treatment process.
All over cylinder-bore treatments, for gosh sakes.
… [A]luminum is an inherently "soft" metal, and cylinder bores of an engine block crafted purely from aluminum wouldn't long withstand the constant, grinding friction of pistons and piston rings scraping their way up and down the bore surface. Most aluminum engine blocks actually are fashioned from an aluminum-intensive alloy that contains other metals, primarily silicon. That helps, but that alone isn't nearly durable enough.
"It's pretty simple," says one OEM powertrain engineer. "You don't want aluminum-to-aluminum contact. You've got to have a bore with a high wear surface, and aluminum has poor wear characteristics."
Thus, the primary reason cylinder bores can't be aluminum. Once it's agreed the bore must be protected, the question is: "How?" Other factors such as cost, manufacturing consequences and performance requirements then must be squeezed into the equation. That's where the cylinder bore-treatment "factions" start to dig in their heels.
The Methods
Broadly, there are two ways to protect aluminum-engine cylinder bores: Either install iron liners or find a way to make the bore surfaces more wear-resistant, usually with some type of coating or treatment of the aluminum. Some approaches use rather exotic and elaborate processes to accomplish this feat.
Iron Liners: The utility infielder
Installing cast iron liners - or "sleeves" - equates to what might be called the industry "default" to answer the cylinder bore-treatment matter. Iron liners have numerous advantages:
- They are probably the most inexpensive method.
- They are delightfully durable.
- They are easily and inexpensively integrated into the manufacturing process.
Cheap and durable - the two words the industry holds most dear, right?
Well, there are problems with iron sleeves.
Sticking iron into your fancy new aluminum engine obviously negates some of what you're trying to do in the first place. Iron is heavy - that's why you switched to aluminum!
Perhaps more importantly, iron liners take up space. A common iron liner is roughly 3 mm thick. Multiply that by the number of cylinders you're dealing with and the engine starts to grow; there has to be a certain amount of block "webbing" between each cylinder to ensure structure, so the room that liners require can't always simply be chopped out of the space between each cylinder.
To now, that hasn't been a big deal in the U.S. One foreign castings supplier, who asks anonymity because he's wooing domestic business, explains: "In the U.S. you have the 'luxury' of displacement. Engines are large, so there is no particular need to use modern (bore treatment) methods. The car companies here always think first of cost and high volumes."
This source's emphasis on the word "modern" is inescapably scathing.
W. Gregory Wuest, vice-president-research and development at Sulzer-Metco, a New York company espousing cylinder-bore spray coating technology, agrees, noting that engines in Europe and Japan must be inherently smaller and more energy dense because fuel prices are so high. "In Japanese engines, for example, there's no room for a liner. They're driven (to other methods) by that factor."
Mr. Wuest notes that spray coatings usually can be applied in thicknesses of no more than 100 microns - one-thirtieth the space each 3 mm iron liner demands.
Iron liners typically are cast into the block as it's being formed. General Motors Corp. employs this method with its Premium V-6- and 8-cyl. OHC engines. Saturn simply presses in the liners. Ford Motor Co., for its Intech all-aluminum V-8s, heats the block and presses in the liners; when the block cools, it "shrinks" around the iron sleeves.
Iron and aluminum exhibit different thermal properties, though, which can be troublesome. And aluminum blocks and iron liners don't completely "bond," regardless of the joining method. That leaves gaps between the liner and the cylinder wall. The bonding and added-weight issues can be improved by using aluminum sleeves instead of cast iron - DaimlerChrysler AG likes aluminum sleeves for Chrysler's 4-cyl. and new V-6 engines - but aluminum liners are tough to cast directly into the block.
If liners are cast into the block - as in the GM method - scrappage becomes an issue. If the entire engine is built, only then to be discovered to be defective, the iron liners must be ripped out and are useless.
"We have some relatively high scrap costs," admits one powertrain engineer.
The Coatings: You pays your money, you takes your chances
This story was born when we first conveyed BMW AG's woes with Nikasil. So let's examine the competing cylinder-coating processes.
- Nikasil: An aluminum engine is dunked in an electrolytic "bath" of free-floating nickel, silicon and other junk. The electrolytic action causes these hardy substances to adhere to the aluminum surfaces.
"It does work very well in a lot of applications," admits one engineer philosophically behind iron liners. But Nikasil's main drawbacks are serious.
First, says Achim Sach, of VAW Motor GmbH, a part of the VAW Group aligned with Mexican casting giant Cifunsa SA, "Nobody wants to have nickel in the plants anymore." Also, as noted in September, high-sulfur fuels eat away at the coating, eventually rendering it useless. Result: ruined engine. And Nikasil has "throughput" issues: The block has to be labor-intensively "masked" before it takes a Nikasil bath, so that the particles cling only to the bore surfaces. And the block has to soak for more than an hour, claim some skeptical sources. Nikasil appears to be on the skids for these reasons. BMW has abandoned the process. Jaguar Cars and Ferrari SpA still like it, though.
There's plenty of industry dissension about the true cost [of various coatings, including {Alusil, Lokasil,- excerpted} and Nikasil], but Mr. Wuest is frank with his figures: He reckons iron liners cost about $1.50 to $2 per bore; plasma coating probably ranges from $3 to $5 per bore.
Meanwhile, Nikasil runs from $5 to $10 per bore, the cost largely dependent on volume.
#2 ·
I would add this as my personal opinion: I prefer the cast iron liners for my (Warrior) purposes. Why?
"- They are delightfully durable"
- They allow for more displacement
- They have proven to work well in many applications, over years and years of use and abuse.
- They can be honed and re-used without costly replating.
#3 ·
You're the only one responding to your post. LOL
Both have advantages, drawbacks, and cost considerations. The stock bikes cylinders are coated and many with lots of miles on them and have yet to have any siezures due to delamination. Consider HDs also which run sleeved cylinders and they have little longevity isues as well. Both are good methods of reducing wear and friction. Given the choice I'd have no problems installing sleeves in a bored out application as it's something I can have done locally if the need arises. Coating is not as simple and requires sending them to a shop that may in all likelyhood not be local. From a simplicity standpoint I'd sleeve 'em.
#10 ·
As far as iron sleeves go, just because everyone is doing it doesn't make it better. Automobile manufacturers will refuse to make a change if they can save a single penny per unit. Racers would use iron sleeves because they are easier to work with and are not concerned about longterm durability. So many people may be doing it, but maybe not for the reasons that would be important to YOU. I seem to remember seeing some pics of Warrior cylinders that had many thousands of miles on them and still had the hone marks in the cylinder. I'll see if I can dig those up.
#11 ·
quote:Originally posted by Modit2thmax
I was thinking ceramic too.
Could be Add Hype...?
http://www.yamaha-motor.com/products/unitfeatures.asp?lid=2&lc=mcy&cid=4&mid=60
""Larger-bore cylinder features cylinder head with larger cooling fins, ceramic composite bore plating and a one-piece head cover (for greater rigidity around the rocker arm) to provide more efficient heat dissipation. ""
#12 ·
Nice work, thanks. I could have sworn I heard ceramic somewhere.
#13 ·
Okay, I just pulled this from another forum at www.dirtrider.net:http://www.dirtrider.net/forums3/archive/index.php/t-64199
This is a post by Eric Gore to a thread titled "Ceramic bore coatings." I have NOT edited it so you can get a feel for Mr. Gore's background. Eric Gore runs a highly respected two stroke engine mod. company.
EricGorr: Coatings and other stuff
Ok guys theres lots of stuff going on here and I'm going to try and cover it without {pixxing} off too many people off in the automotive industry for giving y'all the inside scoop.
Coated Liners – The ad SFO saw in the PRI magazine is for a company named Perfect Bore, located in Andover England. They make liners in a variety of materials and are a preffered F-1 vendor. Materials include aluminum (or as they say in the UK aluminium) steel, and GKN metal matrix composite. Aluminum and MMC liners are used in a wet application for modern F-1 and IRL engines. Steel liners are used in a dry application for cast iron blocks in NASCAR & NHRA applications. They don't make cast iron liners and coat them, that concept would make their CEO Martin Case cringe! Perfect Bore is owned by Performance Motorsport Inc. which is the group that also owns Wiseco, Vertex, and Carrillo. PMI's parent company is Dover Diversified. Perfect Bore's American agent is A.I. LeGrande Wood, known in the racing industry as Woody. He owns DRC (Detroit Racing Components) in Ortonville Michigan. I consider Woody to be one of the most influential innovators in NASCAR racing because he's responsible for adapting and integrating F-1 racing technology in the form of processes, products, and corporate development to American auto racing. He's a smart dude and his son Allan races vet motocross and is a DRN member.
Perfect Bore's coatings are handled by A.T. Poeton & Sons in Gloucester England. That company also owns Max Power Cylinders Inc. in Madison Wisconsin. My connection to these companies started like this; In 1996 Poeton and Perfect Bore started Max Power as a joint venture and contracted me to be the general manager and essentially start the business from scratch, doing site planning, assembling the plant, filing EPA licenses, writing the marketing plan and all the advertisements, hiring and training staff and making the “big machine run”.
Me and Max Power - In 2000 I left my position at MPC because an unqualified individual was hired in a nepotistic fashion by the president of MPC, supposedly to work as my right hand man. He was much younger and was paid much more money than me. This guy hired all of his friends, also unqualified people with no motorcycle industry experience or even basic machining knowledge. The stress of baby-sitting for 75hrs a week was a bit much for me so I re-started my business Forward Motion so I could work one-on-one with my customers involved in motorcycle racing. Contrary to what people on the telephone at Max Power say about me, I gave 6 months notice and fulfilled all the goals outlined by Anthony Poeton including producing a technical manual for performance machining in accordance with a ISO 9001 quality system, a web site, and co-authoring an SAE technical paper that was the basis for marketing efforts to OEMs. All of the negative comments that MPC personel tell customers on the phone about me is untrue, but theres little that I can do about it.
I chose to align myself with US Chrome because Bob Reath, the CEO is an enthusiastic gear-head, with years of experience as a performance innovator and sponsor in IRL and NASCAR racing. USC doesn't compete against me and our businesses compliment each other. Now that we have that out of the way, lets get back to coatings.
Nickel Composite Coatings – Apticote is a tradename for Poeton and NICOM is a tradename for US Chrome. This is an electrolytic nickel composite coating using nickel as the matrix to dispurse silicon-carbide particles evenly across a bore surface so as to provide a load bearing wear resistant surface. The German Mahle company calls their coating NIKASIL and Kolbenschmit calls theres LOCASIL. They're all the same thing, no matter what their ads say about ceramic this or composite that, its all essentially a 30 year old technology first pioneered by US Chrome. {emphasis is Spear Warrior's}
Coating Cast iron – Nickel composite coatings can be applied to cast iron but its difficult because cast iron is a dirty material that requires a carefull pretreatment. Companies like RPM and Langcourt offer cast iron plating in their brochures and they do this by coating the entire cylinder in masking material then exposing only the bore. The reason is that the pretreatment acids used for aluminum and ferrous materials like steel and iron are different and will oxidize the other material. The reason why USC doesn't offer this service for mixed material cylinders like RZ350s is this; if any area of the masking cracks and the acid penetrates it will destroy the aluminum. Most of the people looking to have this work done are doing it for antique parts and USC doesn't want to take responsibility for a loss like that. Read the other companies brochures, they don't take responsibility for it either!
Right now US Chrome is the industry leader in plating cast iron blocks in NASCAR racing. The recent 1-engine rule has facilitated the growth of nickel composite coatings in cast iron engines. The reason why Perfect Bore offers steel liners instead is because their coating plant is in England and its too expensive to send blocks back and forth across the pond. Poeton's also has the ability to coat cast iron blocks and they run a business named APTEC out of their Gloucester works.
Keronite – This is a relatively new coating that's like a super hard anodizing process that penetrates the surface of aluminum or magnesium. It was developed at the Moscow Aviation Agency during the reign of the old Soviet Union. The two Russian-Jewish scientists that developed it left Russia after the collapse of the Soviet Union. One went to Isreal and started a company called Al-Mag. The other man immigrated to the UK to start Keronite. The main benefits of the coating is that it produces a wear and corrison resistant coating on aluminum and magnesium, without producing any hazardous waste. A tank of electolyte solution contains a high energy anode and parts for coating. The energy required for this process is tremendous and special cooling capabilities must be added to the process. The only Keronite plant in operation in the US is at Max Power in Madison Wisconsin. Anthony Poeton has started a new Poeton group company named Magnesium Coating Inc. to go after the market for corrision resistant magnesium products.
Al-Mag markets the coating in Isreal and the biggest use of the coating is for cylinder bores on 2-cycle drone airplane engines. Last year USC had some cylinders coated by Keronite UK. The cylinders were honed and tested for wear resistance, thermal transfer, and friction. The results were compared to nickel composite, MMC, and cast iron bores in an SAE paper presented at the 2001 SAE Congress meeting in Detroit. The paper was authored by Dr. John Carpenter and is available from the SAE Bookstore or by request from US Chrome. The results show that Keronite is not a great bore coating because it has thermal barrier characteristics and is relatively soft compared to nickel composite. But it is cheap, disposable, and hazardous waste free. Once a cylinder is coated with Keronite it can't be repaired like nickel coatings which can be chemically stripped. However there are many great uses for Keronite and if you work at a company that makes aluminum or magnesium parts that require wear or corrosion resistance, contact Anthony Poeton at 1-608-224-2524 to get some tech info on the benefits of the process.
#15 ·
I am interested Spear, I just wonder how thick the jugs are to begin with the standard 97mm bore. the 108" bores it to what?? 100mm.?
A boring out to 110" and the additional bore for the sleeve would be how much.....and how much thickness is left in the thinnest part of the bore?
#16 ·
I'm sorry to have to do this....but the facts are pretty simple:
You guys are so worried about excess heat in your big bore-cast iron sleeves dissapate heat at 1/3 the rate a like mass of aluminum will.
Aluminum and cast iron have very different rates of expansion when heated to the same temperature. An air cooled engine relies on the air around it to cool it and to a leeser degree the oil, do you really want these two disimilar materials expanding and contracting as much as they will (at different rates)in your engine? This tends to be less of an issue in liquid cooled motors as they cool down and heat up as much slower rates.
"Iron and aluminum exhibit different thermal properties, though, which can be troublesome. And aluminum blocks and iron liners don't completely "bond," regardless of the joining method."-thanks Spear
Nikasil cyclinders have a higher Rockwell hardness rating than cast iron and by design are oleophilic (Having a strong affinity for oil). Both of these factors contribute significantly to engine life and wear issues.
Spear brings up the point in his first post about the sulfer in the fuels and potential for problems, I have yet to see this problem in any motorcycle (certainly there are Road Stars out there with 100K on them without this issue coming up as well as loads of BMW's....in all of my research I saw that BMW auto had some problems with this and to a much lesser extent Jag, it's in my opinion that there is some other contributing factor that is contributed and was catalist to this problem.
Here is some additional info I found on the web:
http://autozine.kyul.net/technical_school/engine/tech_engine_6.htm
Instead of cast iron liner, Nikasil treatment coats a layer of Nickel-silicon carbide, usually by electrolytic deposition, to the inner surface of aluminium cylinders. Since Nikasil layer generates even less friction than cast iron liner, revability and power are both enhanced. Moreover, it is only a few hundreds of a millimetre thick, therefore the spacing between adjacent bores can be reduced considerably, making the engine smaller and lighter. Since the early 70s, Nikasil treatment has been the most favourable solution used by high-performance cars.
_____________________________
www.us-engines.com
A relatively new technology for smaller sized engines. NikasilTM is the trade name for German piston maker, Mahle'sTM patented nickel-silicon oxide cylinder plating, and plating process. This Technology was developed, in 1970, by MahleTM, with Porsche AGTM. It replaces, and is far superior to, sleeved and hard-chromed cylinder walls. Why?
Cylinder Walls are literally impregnated with silicon, resulting in a super low coefficient of friction, thus reducing engine heat and wear. Piston and cylinder expand at the same rate, thus, creating a seizure-resistent engine.
Lower friction also means easier and quicker engine starts.
Engines run cooler and with less vibration.
GroundhogTM engine temperatures were compared, (at 7,000 rpm) to other brands, (hard chromed), the result... Groundhog 41TM engines averaged 285°F, the others averaged 310°F.
Interesting trivia...The majority of Formula 1™ racecars use NikasilTM plated cylinders, including drivers David Coulthard and Mika Hakinen, and their Mercedes BenzTM, as well as Rubens Barrichelo and Michael Schumacher and their FerrariTM.
www.rpmsbigbore.com
Our plating and finish work is the best in the industry. Our repeat customers include FMF, Pro Circuit, White Brothers, YOT, Team Green, Factory Kawasaki/ Suzuki /Honda/Yamaha race teams and R+D Departments, Yamaha and TM warranty departments, ATK, NCY, Bills Pipes, Noleen Racing, AC Racing, Hinson Racing, Chapparral, MSR, Wiseco, JM Racing, MTC, Z-Racing, Yoshimura......and many dealers and race teams throughout the world.
Why nikasil and not a sleeve?
A: Nikasil lasts much longer, dissipates heat better, matches the ports better and makes more power. The only modern MX bikes that still use sleeves are the CR-500 and RM-80. Both are a dozen-or-so year old designs. Nikasil is used in all other MX bikes, all BMW motorcycles, Most Porsche, BMW and Mercedes cars, most outboards, the top of the line Snowmobiles and Personal Watercraft also run nikasil cylinders. FZR's, GSXR's and soon American cars are converting to nikasil.
Porsche 901 Engine Series http://www.ramaircraft.com/
NASCAR Winston Cup, BMW, and Porsche!
from 9,600 cylinders delivered during the past five years. Engine Components, Inc. ( ECi ) offers us a proprietary nickel and silicon carbide composite applied to the bores of their PMA new cylinders.
We use either their PMA new cylinders, or we have them apply their composite to the new OEM cylinders we use.
Following are quotes from Engine Builder Magazine, Nov. ‘02, Vol. 39, No.1. The Smooth Science of Cylinder Honing, by Technical Editor, Larry Carley. He notes:
“In recent years, Nikasil™ cylinder bore coatings have provided a [honing] challenge for engine builders. Nikasil™ is a hard coating of nickel and silicon carbide about .0025” to .003” thick, applied to cylinder bores to improve wear resistance.”
“Invented by the German firm Mahle, Nikasil was originally developed for the Mercedes ****el rotary engine. It has been used by BMW and Porsche in some of their engines, and is also used in some motorcycle and marine engines, and even many NASCAR Winston Cup engines.”
Kiebler explains,“NASCAR Winston Cup shops are using Nikasil™ cylinders. If it's good for NASCAR, it's not going to be long before you start seeing it in OEM engines.”
These industry icons of engine performance are using Nickel/Silicon Carbide cylinder bores to achieve durability, referred to as Nikasil.™ From experience, they know that cylinder bore quality plays a huge role in reducing friction and blow-by for improved engine performance and durability, and they are not in a position to be wrong about cylinder performance.
RAM has achieved durability too! No premature wear or corrosion
http://www.electrobuild.mb.ca/page2.html.
A coated cylinder was brought into the production of snowmobile engines for many reasons. i.e.: tighter tolerances, better wear resistance, exceptional oil retention, high temperature resistance, better coefficient of expansion with aluminum cylinders. All in all you get better performance than a cast sleeve.
www.walkerjet.com Nicasil is an expensive technology used for coating the cylinders of only the best quality engines on the market. It is far superior to sleeved and hard-chromed cylinder walls. It is a coating made up of nickel and silicon carbide. The Nicasil coating is very hard and durable thus providing a very long wearing surface for the piston and rings. Also the silicon carbide particles that are dispersed throughout the nickel form a multitude of adhesion spots on which oil can collect. This is another reason that engines with Nicasil coated cylinders last longer because of having improved cylinder lubrication. Also because the Nicasil coating literally impregnates the cylinder walls with silicon the result is a super low coefficient of friction, thus reducing engine heat and wear. Engines with Nicasil coated cylinders run cooler and with less vibration. Lower friction also means easier and quicker engine starts. Also an additional benefit is that the piston and cylinder expand at the same rate, thus, creating a very seizure-resistant engine. In racing two strokes both Morbidelli and Rotax have had great success with Nicasil and it is used in the most expensive professional grade chain saws. Porsche uses Nicasil in their turbocharged 917-935 series of race cars. In fact the majority of Formula 1 race cars use engines with Nicasil coated cylinders. Although the Nicasil process is very expensive, the resulting increase in the engines life span, performance and reliability more than offsets the cost. That is why WalkerJet only uses engines on their paramotors that have Nicasil coated cylinders.
Harpers Moto Guzzi www.harpermotoguzzi.com/parts.htm
Why have your cylinders Nikasiled? You get much better results than with the steel sleeves. Nikasil dissipates heat much more efficiently than steel. The cylinder walls are treated with the special Nikasil electroplating. Nikasil coated cylinders have a hardend surface that cannot peel and is more wear resistant than the steel sleeves.
Although the Nikasil process is expensive, the resulting increase in the cylinders life span, performance and reliability more than offset the cost.
Let's talk about cylinders www.recpower.com/hirth.htm
Most engines on the market today are built with steel sleeve cylinders. Although steel sleeves are less expensive than Nikasil, steel cannot dissipate heat as efficiently as aluminum and expands at a slower rate. As the heat in a steel sleeve cylinder engine increases the piston expands faster than the cylinder wall, steadily decreasing the piston clearance. To compensate for this, engines utilizing steel sleeve cylinders, must run lower CHT and EGT temperatures. Hirths' cylinders are of aluminum alloy; there are no sleeves. The cylinder walls have been treated with the patented Nikasil process. Nikasil coated cylinders have a hardened surface that cannot peel and is more wear resistant than steel sleeves. Because the cylinders are still an aluminum alloy, their expansion properties as well as their excellent thermal conductivity are virtually unchanged. This design allows heat to be dissipated quickly and efficiently. The piston is also made from an aluminum alloy. The piston alloy is slightly different and expands slightly less than the Nikasil cylinder. This combination of cylinder treatment and matched cylinder and piston materials creates an extremely seize resistant environment. This is also why Hirth engines can handle cylinder head temperatures of over 600 degrees F. without failure. Although the Nikasil process is very expensive, the resulting increase in the engines life span, performance, and reliability more than offsets the cost.
Hirth Engine Modelshttp://www.mt-llc.com/technology/index.shtml
Please be sure to read this artical as well:http://www.mt-llc.com/technology/98winter_snowtech_article.pdf
Just a few Nikasil'd cars you MIGHT have heard of: LeMans and Daytona winning Audi R8's, 2005 Porsche Carrera GT, Ferrari Enzo, all Formula 1 cars........and your everyday Warrior and Road Star.
Silent, now your head must really be aching.
If I don't respond to the answers on this post please forgive me, I'll be on vacation starting in about 6hours and will be back on April 5 to answer.
With all of that being said, you can see why we prefer the coated method over sleeving and why in our 122ci motor we suggest it's designed to be in more of a bar hopper type bike than an everyday rider, because it too is sleeved. We have several hundred of our Big Bore kits on the road currently and have yet to have a single problem (remember we have been selling them for the Road Stars for a few years now). The technology and engineering leave little to no room for problems to ever arise, the technology and engineering that PR uses I am sure is tops when it comes to sleeving a Warrior, and I'm sure failure is uncommon, but it doesn't eliminate the basic issues and areas of failure a sleeved cylinder MIGHT have the way a bored and NSC coated cylinder does.
Sure PR machines in the "squish ring" but they need that when you have the differing rates of expansion between the heads and the cylinders. The only times we have had any problem with proper head sealing was with shops of questionable "Yamaha v-twin" mechanical ability.
Well then again there is the nagging "problem" (note how it's in quotes) of the stripped cylinders...if it's that much problem for your to buy some paint, masking tape and sand paper...then maybe you should re-read the first four points of this post...plus it'll do you some good to "bond" with your bike a little and have some pride in re-finishing your cylinders all by yourself.
Ok I am out of here this post took me over 3 hours to research and write...time to get to bed, I have an appointment with Mickey!
#20 ·
Rob, I must commend you for doing such a good job promoting Nikasil and Orient Express! [/emoticons/emotion-5.gif]
However, I believe there is room for a difference of opinion, based upon facts.
First, the engines you often refer to in your posts, both here and otherwise, are high-revolution, high performance engines which, I would think, create a much greater degree of friction and heat than would a 5,000 RPM limit motor, such as our Warrior engines. Therefore, the advantages of Nikasil are much more pronounced with them.
Second, I do NOT believe for one moment that an aluminum cylinder with a PROPERLY MANUFACTURED cast iron liner is either unreliable or undesirable. If so, I don't beleive the majority of the world's manufacturers would still be using this process, nor do I think that BMW auto division would have returned to this process after having major FAILURES using the Nikasil process. To quote from the article in Web's Auto World, "They {Cast Iron Liners} are delightfully durable."
Also, "Iron liners typically are cast into the block as it's being formed. General Motors Corp. employs this method with its Premium V-6- and 8-cyl. OHC engines. Saturn simply presses in the liners. Ford Motor Co., for its Intech all-aluminum V-8s, heats the block and presses in the liners; when the block cools, it "shrinks" around the iron sleeves." Obviously, these companies do not have failures in their engines due to excessive heat or wear. These same American engines will go 200,000+ miles without a rebuild if basic mantainence is performed.
Third, one MAJOR reason to a shift to Nikasil is that it meets the requirements for packaging an engine as small as possible for any given power output, a problem our Warrior engines do not have. From the article, here is a quote ". . . Perhaps more importantly, iron liners take up space. A common iron liner is roughly 3 mm thick. Multiply that by the number of cylinders you're dealing with and the engine starts to grow; there has to be a certain amount of block "webbing" between each cylinder to ensure structure, so the room that liners require can't always simply be chopped out of the space between each cylinder." If you are designing a new four cylinder motorcycle engine, there is NO ROOM for Cast Iron liners. Again, the Warrior engines do not have this packaging problem.
To ignore the sulfer issue with Nikasil is to ignore one of its major problems: "But Nikasil's main drawbacks are serious."
"Also, as noted in September, high-sulfur fuels eat away at the coating, eventually rendering it useless. Result: ruined engine."
In certain parts of the U.S., you can still run into gas that has high-sulfer content. Do I think this is going to be a major problem for most of us? No. Is it a fact? Yes. Just as much as any fact raised about the Cast Iron Liners.
And I must point out for our members and other readers an apparent discrpency in comparing VW and Porche engines to our Warrior engines using Cast Iron Inserts. Here is a quote from your post . . .
"What's Wrong with Cast Iron Cylinders?
A quick survey of performance aircooled engines will find that VWs are unreliable, but the Porsche 911 is so reliable that in both production and racing it seems to last forever. It is not unusual to see a stock 911 engine exceed a life of 200,000mi+. Why? One of the major differences lies in cylinder design!
All stock VW, Porsche 914, and Porsche 911T aircooled engines and the vast majority of modified ones use cast iron cylinders. {Spear's comment, yes that is an ALL CAST IRON CYLINDER, not an Aluminum Cylinder with a Cast Iron Liner Insert . . . major difference, IMHO [/emoticons/emotion-5.gif]} One of the major problems with cast iron cylinders is that they are thermally overloaded! Note that the aforementioned 911T has the only 911 engine ever to receive cast iron cylinders due to its detuned, low performance nature. These engines, at their maximum 2.4L, had just an 84mm bore and produced about 22hp per cylinder, and that's with a superior cooling air system. It should now be apparent why putting out 50hp per cylinder on a 4-cylinder, 200hp engine with cast iron cylinders surely results in failure!"
There is a big difference between the whole cylinder being made of cast iron and a cylinder being made of aluminum with only an iron liner in it. A "sleeved" (with a Liner) aluminum cylinder is going to dissipate heat much, much more rapidly than the solid cast iron cylinders being used as examples above. Readers should also note that of the two Big Bore Kits currently offered for our Warriors, there are only two types: Aluminum Cylinders with Nikasil Plating and Aluminum Cylinders with Cast Iron Liners. The Warrior motors that have won two NHRA titles and the Bonneville Land Speed Record title for class all use Aluminum Cylinders with Cast Iron Liners.
Readers will please note that I have never, never said that Nikasil was either bad or unreliable. Quite the opposite is true. However, this is not a zero-sum game. Nikasil can be quite good, but so can Aluminum Cylinders with Cast Iron Liner Inserts. It depends upon the application.
So, it comes down to this for me. What is the application and what am I LOOKING FOR? The application is a slow revving, long stroke engine that is moving a very light-weight load. I am looking for the largest cubic inch engine I can obtain, without risk of reliability.
Will Nikasil provide excellent protection for our engine's aluminum pistons/cylinders? Yes, in MOST instances, sulfer being the main issue, Nikasil will be fine.
Do you need MORE MATERIAL in an all aluminum cylinder to be as structurally sound as a thinner-bore cast iron liner? Yes, you WILL NEED MORE MATERIAL. Hence, OE can only offer their Big Bore Kit up to 100mm bore (108ci) with the Nikasil coatings.
Will a Cast Iron Liner provide excellent protection for our engine's aluminum pistons/cylinders? Yes, in MOST instances, constant use in only "stop and go traffic" being the main issue, Cast Iron Liners will be fine.
Can you use LESS MATERIAL in an aluminum cylinder with a Cast Iron Liner? Yes, you can. Hence, Patrick Racing can offer a 101mm (110ci) Big Bore Kit.
So, to me, it comes down to this, again. What do I want? I want the biggest, meanest engine I can get! I want excellent value. I want proven performance from a proven company. I want reliability that has been proven "on the track, in the winner's circle." I think Patrick Racing's 110ci Kit gives me all of that. [/emoticons/emotion-2.gif]
Again, no one ever said on this thread that Nikasil was bad. However, there does seem to be a strong inference that Cast Iron Liners in ALUMINUM CYLINDERS are unreliable; that, I firmly believe, is JUST NOT TRUE.
#22 ·
Modit2thmax, I'm assuming you're speaking to me?
No, I have my order in for $715.00 plus core deposit. Bismark at Cycle Image took care of that for me!
But, let me ask this question. What is this forum about? I think it is about sharing ideas, helping one another out in times of confusion or need, and generally communicating with others who have a passion for their bikes . . . Warriors.
As some may have noticed, I do get a little "focused" on certain things. One is the issue of Nikasil vs. Cast Iron Liners. I believe there is room for both processes, but I don't think both sides have received fair treatment. I like fair. {See my signature for further proof of that!}
So, I'm trying to do something about that. I hope I'm helping some of our members, that is my SOLE intent. You guys have sure helped me out from time to time. I'm just trying to repay, that's all.
By the way, "COMMUNICATIONS" is a major part of my job description, so I guess running my "mouth," so to speak, comes naturally.
#23 ·
Sorry, I was TRYING to be funny
#24 ·
Hey Modit, No Offense taken, really. [8D]
Sorry I'm so serious about some of this stuff. It's just that to some guys (me included) $700 - $800 is a bunch of money.
I kind'a feel like I'm making more muddy water than clearing anything up. [V] Anyway, I am sincere, if possibly ineffective. [/emoticons/emotion-5.gif]
