Question on a power commander
1.7K views 13 replies 10 participants last post by  RickPullins
I'm waiting for my Warrior to get in hopefully by mon. or tues. anyhow, I plan on installing a Cobra power commander, can it be installed right away or must the bike be broken in first[?]
#5 ·
quote:Originally posted by Meltdown
Breaking in is all about rpm's and not getting on it too hard too soon.
Is that a can of worms that just popped open? You'll hear many different opinions about break in. My opinion is that the proper break in for a Warrior is letting it idle for approx 5 minutes the very first time you start it. Then climb aboard and ride it like you stole it!! Always let it warm up then jump on it. For 35 years I have been breaking in engines like that with no problems at all. First oil change somewhere between 100 and 150 miles. Next oil change between 5 and 600 miles. Then, at 1200 - 1500, switch to synthetic oil. PCIII can be put on right away.
#7 ·
You can install it right away, but remember that any problems are most likely to show up in the first few hundred miles. A PC could give your dealer a reason to fight you on a serious warranty claim. They, the dealer, ultimately have to prove that your mod caused the failure, but ask yourself do you need the extra hassle? Thats why I waited for the first 1k miles to roll by before starting any mods to the engine.
#8 ·
quote:Originally posted by ErnC
OldMan' Have all your engines, for 35 years, had nikasil coated bores and would that make a differance?
Simply put, they did not, and I haven't got a clue. [/emoticons/emotion-4.gif] That's how i did the break in on my Warrior and it runs very strong, no oil useage at all.
#9 ·
Old man, I am with you. I have alwats broke them in the way I intended on riding it for it's lifetime. However, there is someone on here that will tell you that doing that will cause glazing of the cylinders or something like that. I think it may have been ChurchKey. There is a thread on here that you can search for that is specific to breaking it in.
#12 ·
OldMan, I think "Break in IS way in the past!". Cylinders are no longer cross hatched w/ridged rings to wear in, this used to be the most important part of break in. Now it's just all the other moving parts wearing into each other. I think regular oil changes and not lugging it will do just fine, but it's no longer our problem/just new owners. Like you say "Break in is way in the past!"
