Don't have any pictures readily available, but I can tell you this. I cut the top part of the airbox with a dremel and installed Woody's VBAK. I had 3 reasons for doing so. One was, I could not get the air temperature sensor off the box without destroying it. Two, I wanted to reattach the rubber snorkle back and use a velocity stack to create a ram air to feed cooler air into the airbox. Thirdly, I noticed that with the airbox surrounding the K&N filters, they stayed clean for a longer period and picked up less dirt and grime. I also insulated the underside of the airbox with reflective tape to deflect some of the heat from the engine during standstills.
