OK, a search brought up 36,678 items so I thought I'd risk another post with that title rather than wade through that lot:}
If you have done the swap to the R1 forks, I'm interested in hearing your opinion on how easy it was, what you actually had to change ie, brakes/triple clamps/wheeletc, is a new wheel required, which R1 forks lower the Warrior and by how much (I want stock height), does the Warrior fender fit any of the R1 forks, if it's actually worth it, what was the result and have you then modified/swapped the rear shock. I'm thinking a change to the 99-01 fork would be a good upgrade but am not exactly sure what I need so any help would be appreciated. Thanks very much and have a great weekend:}
