R1 front fender
2.3K views 28 replies 11 participants last post by  Daimon1054
Any one know if a 1998 front R1 fender is the same as 2002-03 R1 front fender.
#7 ·
Puya is right. I have a 03 R1 fender on my 02 R1 forks, but the 01 is different. If you sweet talk your parts man , you may be able to pick up a new fender for about 89.00. Stay off e-bay though, thery're generally trashed and people want too much for them. FYI, the gap btwn the fender and 18" tire and rim is pretty tight, it'll fit but leaves little room for gravel to get through. Being a FL resident I only have to worry about sand so this is not an issue. Up in Deals Gap, there was a bit of gravel around and I was scratching my head trying to figure out what all the noise was coming out from under the tank.[xx(] Turns out it was the small rocks shooting out from the fender.[:0]
#13 ·
The earlier R1 fenders (pre 02) can be retrofitted to the Warriors legs but I'm not sure how they'll fit onto the 02 and up R1 fork legs. They did look close when Billy and I were together. I'll check into it further. For now here's the best pics I can come up with. 01 on top, both in the middle and 02 on the bottom. I'm sure someone here has a clean shot of an early model R1 for better comparison.
Image Insert:
Image Insert:
Image Insert:
#16 ·
sushiwarrior the most expensive part is going to be the paint!
Church sent me a drawing of the mount and it is easy to make. If you want I will forward it to you.
On e-bay right now there are tons of front fenders. New is like 80 bucks and if you look you can get them for under 40 used and in good shape just needing paint which even new will need.
Like you I like both and am getting one and don't care to much about the year, I may just need to mod the mount but that's no big deal.
#17 ·
And in my looking I saw several sites in Japan with pics of fenders. Not sure what #$%@ #$ $#$# #@% %#%$ and a letter that looked like a upsidedown house with a goat in it meant but I know they were selling them /emoticons/emotion-1.gif
