1 - 2 of 2 Posts
Has anyone put a racked front end (triple tree) on a Warrior? I have a 2003 and want push out the front end a bit. I would like to hear from anyone that has done this and how it changed the handling of the bike.
You might want to do a search. Try "raked triple trees" or " 6 deg trees" . Lots of info floating around. That being said having raked trees alone will drastically drop your trail #'s. Mine tended to want to fall into turns easily but then you had to hold it there. If you decide to do it I would suggest going with the mortons 7 deg tripple trees with 2 inch fork tube extensions. This way you will keep your stock ride height.
1 - 2 of 2 Posts
