Thanks for the replies - I had tried the screwdriver trick (that's how I broke the clutch ass'y), lubed it, sanded it, etc., and it still won't go over the bulge.
On the throttle side I had all of the same problems: I ended up sanding and scrubbing the bar, then lubing it and the inside of the throttle before it would operate freely.
Knowing what I know now, I would, at the least, spend some time w/ a dremel cleaning all of the holes up, and test fitting everything very carefully to ensure a trouble free installation - it would have been much easier to do this before the bars were installed.
On the positive side, Redhorse's and Darkstar's installation instructions are excellent, tho' I would add a couple of items: use heat shrink tubing (available from Radio Shack) instead of electrical tape, and I used kite string w/ a vacuum to pull the wires thru (electrician's trick). Just tape up the wiring holes, and put the vacuum on the bar end, leaving the end cap on the other bar end; tie off one end of the string to the headlight mounting tab, and it'll suck the string thru in a heartbeat. I also used alot of white 18 gauge wire: use a permanent marker to put a tracer color on it and you can make almost any color wire you need.
Final resolution on the bars (from the vendor): file the offending bump until it fits! Needless to say I am severely disappointed in the quality control of the Radius bars, especially as this is my first ever experience w/ them.
Thanks to all,
Kevin
