1 - 5 of 5 Posts
Well, the dealer installed my new drag bars with the stock risers. Only problem now is my cables are about 6-8 inches longer than they need to be now. It is making the throttle stick because the cables are bent so badly. This is a slight oversight on my part and need someway to fix it as soon as possible. Anyone have cable suggestions or what I can do to remedy this?
Thanks!
I definitely want to keep the look that I have going with the short risers. I don't want pull back risers or anything of that nature. I bought aftermarket risers and they gave the bars a shorter stance than the stock ones. The bars were hitting the top of the fork tubes so I couldn't use them.
Atomic Ed, can you elaborate on what you mean by crossing the cables under the left side of the headlight? I've got the same problem as Tw1sted. Love the bars, but I have a hard time justifying spending $100 on cables that work with $75 bars (bought 'em used).
1 - 5 of 5 Posts
