1 - 17 of 17 Posts
Hey all..
I just removed the bracket that holds the tail lights and licence plate... and in the process broke 3 of the 4 rusty bolts!
any of you know any way of recovering from that short of paying $1000 for a new fender??
I don't really think i can get a drill in there to get the stuck bits of bolt out
248689
248690
The best bet is to remove the fender as to work comfortably. Spray the crap out of them with PB blaster and keep trying. Also you can try to drill them out but put something on the backside so you don't go thru.
Sorry that is all I got right now.
Hey all..
There are professional pneumatic and Hand Tools to Install Blind Nuts & Studs.
Blind threaded studs or pull-up studs can be used for this repair. You'll need to drill out the broken stud and re-drill for the proper body size of the M6 stud.
  • I've seen a neat repair to the Warrior rear Fender Taillight M6 Stud by Gav aka Caledonian Warrior recently over on FB. If interested, in his repair, I suggest you contact him.
I think the installation of a Blind Nut will be more challenging because of its installed position but perhaps I'm wrong.
  • I would suggest drilling out the broken M6 Hex Screw and rethreading if required.
Discussion Starter · #6 ·
Gonna call my local bikeshop tomorrow see if they can help me out.. i just don't have the tools to dril out and retap these nuts..
and as i don't have any other means of transportation it kinda needs t happen soonish
LED strip is a good idea but then what about the licence plate.. i'm not allowed a sidemount here legally and have already been in trouble for not mounting it straight enough..
thnx for all the suggestions guys
Haha! Classic! On my previous warrior fell off such 2 mounts of 4. I puted the blame on the national format of license plates, with us they are HUGE (and terrible looking))) But it turns out that this is a warrior's problem.
If the suggestions don't work get a fiberglass replacement fender you could get a stock design a shorter stock design or even a custom design and the license plate holder could be build in a lot less than $1000
Discussion Starter · #9 ·
well.. i'm saving up for a fibre front fender anywho.... combined shipping myte save me a couple o bob
btw Christok.. is it possible to wrap fibreglass in vinyl straight away or does it need paint 1st?
It would depend on the product. most fiberglass products come with gelcoat which after a degrease/dewax should be able to be wrapped in vinyl right away as long as there are no defects that need to be fixed. Any product I make I presand and then coat with primer which after a sanding with 600 or lighter sandpaper could then be covered with vinyl
Yamaha Warrior XV1700
Why not just spotweld a replacement bolt on top of whats left of the broken of bolt. First clean the area and grind down the remains as much as possible then spotweld
the same diameter bolt in place. Or you can spotweld a nut there instead of a bolt
Just be careful with too much heat and the paint.
I believe he said he didn't have the tools to drill out and re-tap whats there....My guess is he doesn't have a welder to do said tacking of new bolts. Good idea though!
Discussion Starter · #14 ·
The fender is at the local bike shop atm.. we'll see what they come up with.. and then i'll have to see IF i can save the fender long term because of rust, my front fender already has a hole rusted right through.. so i'm talkin to Christok to see what kinda fenders he can brew up for me, that doesn't help me short term but i'll never have to worry about rusty fenders ever again.
r1rouse is correct though, no welding equipment here at all.. and the only drill i have that's powerfull enough to tackle steel is too long to fit in the fender, hence i couldn't drill out those bolts here myself..
if i'm going for a new fender i'll also be looking for a solo seat, something i've been wanting for years (lemme know if ya have a spare one)
Discussion Starter · #15 ·
Update..
The fender came back from the bikeshop.. it is in rusty but useable condition, i've slapped on some anti rust paint.. but i think the damage is already mostly done.
The solution the shop came up with is to cut off the tabs that hold the threads and drill right through the fender which isn't perfect but i can at least ride till my new fender arrives, which being handmade and ordered today is gonna take a while. I did wrap the thing in vinyl like i was planning even though it's ust temporary, i didn't have enough of the stuff for both front and rear fender and the minimum order of the stuff will easily do both.
248770
everyone who replied with good ideas: THNX
Looks good. If you didn't know you'd think the rear bolts are supposed to be there.
Looks fine like that...like madtom said...I would not worry about it any further
1 - 17 of 17 Posts
