1 - 5 of 5 Posts
Going over the manual its seems my rear shock was adjusted wrong. It was at 46mm.
I lifted the bike and adjusted it as far as I could before the spanner started slipping and I didnt feel comfortable putting my back into it with the bike on a hydraulic jack lift.
Am I measuring this wrong? 52mm is the softest setting but it's getting real tough to go further then this without two hands and maybe a better spanner wrench.
Discussion Starter · #3 ·
Here you go and take weight off rear wheel when checking DIM!
Interesting that is different then the manual I downloaded online. Has a different measuring point.
Adjust the shock with weight on the rear wheel. It's easier & safer too!
Take weight off rear wheel when checking DIM!
There are only a limited amount of threads so no need to measure.
Here's what stock adjust looks like with Eibach spring.
Discussion Starter · #5 ·
Is this what the stock spring should be set at as well? Mine is much more compressed
1 - 5 of 5 Posts
