1 - 20 of 23 Posts
Is this the typical tire wear on a Metzler 210 after 4902 miles and no burnouts [?] Stock rear Battlax lasted 8700 milesThere is no visible contact with any inner fender parts or bottoming out [/emoticons/emotion-6.gif]
That is normal for that wide tire on the factory narrow rim. It makes the tire more round then it should be.
Your photo shows you are WAY OVER the wear bar (obviously) and the tire looks over-inflated. How many pounds you running in it?
Also, I have about 4K on my Metz 210 now and I an still not quite at the wear bar. You guys must drive the everloving crap out of yours to get so few miles out of them.
2500 I got only 2000 from mine.[/emoticons/emotion-2.gif]quote:Originally posted by ehacker01
4900 miles? I only got 2500 out of mine.
Discussion Starter #14
I use a digital tire gauge religiously for my pre-ride inspection and run 38~40 psi cold on the rear.Regarding the wear bars....WHAT WEAR BARS [?]....there aren't any that i ever recognized and BTW the cords just appeared the last 90 miles of use [/emoticons/emotion-6.gif]Regarding my driving behaviors....no different than the original tire [V]quote:Originally posted by JimB
Alan - There are wear bars on the Metz, my friend. If I had my camera here I'd snap you a picture and show you, but it's at the office.
They're located right in the middle of the tire... or were, in your case. I didn't know the tire had wear bars either until a few weeks ago when a BMW mechanic I was talking to showed them to me. I thought I was doing real good tread-wise until he showed me I was about 1.5 mm's from hitting the wear bar. Most guys in here will tell you 5,000 on a Metz is great (you have 4900). I personally think this tire is good until 4500 (my riding style) when one should shop around for a replacement. I know I am. I'm going back to a Michelin 200 which lasted me 6,000 as soon as I can find the best deal on one via the Internet. That tire should cost around $155-160, and I've seen them as high as $220.
I found the 210 to be very inconsistant for wear. The tire pictured above was ridden mostly two up riding (300lbs total weight) and alot of highway riding and a few hard pases on the dragon two up (see my gallery).
I've got to echo Gunny regarding the inconsistant wear of this tear. The first one I had looked like the pic Gunny just posted at 1500 miles. The one I have on now has 4000 miles and no cords yet.
1 - 20 of 23 Posts
