1 - 15 of 15 Posts
A working list of tires for the Warrior. Its not a complete list.
Its purpose is to look at each tire's actual dimensions for
fitment purposes. This list includes wheel diameter and
width to clear swingarm.
REAR TIRE
Warrior Rear Tire Options for Stock Fender:
OEM Dunlop D220 200/50ZR17
. Tire Width: 194mm = 7.64"
. Tire Diameter: 635mm = 25.00"
. Tread Depth: 6.5mm = over 8/32"
. Rim Range: 6" - 6.5" recommended
. Capacity: 853 pounds
. Weight of Tire: not listed
OEM Bridgestone BT020 200/50ZR17
. Tire Width: 201mm = 7.91"
. Tire Diameter: 631mm = 24.84"
Avon Storm 2 Ultra 200/50ZR17
. Tire Width: 203mm = 7.99"
. Tire Diameter: 630mm = 24.8"
. Tread Depth: 6.8mm = over 8/32"
. Rim Range: 6" - 6.5" (6.25" rec)
. Weight of Tire: 16.56 pounds (16 lb/9 oz) (7.51 kg)
Avon Storm ST 200/50ZR17 (discontinued)
. Weight of Tire: 16.5 pounds (16 lb / 8 oz) (7.5 kg) (post office scale)
Metzeler ME880 200/50ZR17-Bw (see Bruce59's comments below)
. Tire Width: 193mm = 7.60"
. Tread Depth: 6.3mm = under 8/32"
. Rim Range: 6" recommended
. Weight of Tire: 15.84 pounds
Shinko 009 Raven Radial 200/50ZR17
. Tire Width: 200mm = 7.87"
. Tire Diameter: 632mm = 24.88"
. Tread Depth: 5mm = 0.200" (under 1/4")
. Rim Range: ~6.25" recommended
. Weight of Tire: 15.2 pounds
Shinko 011 Verge Radial 200/50ZR17
. Tread Depth: 6mm = 0.235 (under 1/4")
. Weight of Tire: 16.0 pounds
Metzeler ME880 210/50ZR17-Bw (discontinued)
. Tire Width: 210mm = 8.27"
. Tire Diameter: 642mm = 25.27"
. Tread Depth: 5.5mm = 7/32" (under 1/4")
. Rim Range: 6" - 7" recommended
. Capacity: - 882 pounds
Metzeler ME880 Radial 240/40VR18-BW
. Tire Width: 9.41"
. Tire Diameter: 25.78"
. Rim Range: 8" to 9"
. Capacity: 963 pounds
. Weight of Tire: 17.66#
Pirelli Diablo Rosso II 240/45ZR-17 82W
. Tire Width: 235mm = 9.25"
. Tire Diameter: 648mm = 25.5"
. Tread Depth: ~6mm = 7/32"
. Rim Range: 8" - 9" recommended
. Capacity: - 1,047 pounds
Dunlop Elite 3 Radial 250/40VR18-BW
. Tire Width: 10.02"
. Tire Diameter: 26.20"
. Rim Range: 9" recommended
. Capacity: 1,019 pounds
Avon Cobra AV72 Radial 250/40VR18
. Tire Width: 251mm = 9.9"
. Tire Diameter: 655mm = 25.8"
Metzeler ME880 Radial 260/40VR18-BW.
. Tire Width: 10.19"
. Tire Diameter: 25.98"
. Rim Range: 8.5" to 9.5"
. Capacity: 1,074 pounds
. Weight of Tire: 17.73#
Warrior Rear Tire Options for Wider Custom Fender:
Metzeler ME880 Radial 280/35VR18-BW.
. Tire Width: 277mm = 10.91"
. Tire Diameter: 655mm = 25.79"
. Rim Range: 9.5" - 10.5"
. Capacity: 1,102 pounds
. Weight of Tire: 18.23 pounds
Avon Cobra AV72 Radial 280/40VR20-BW (20" wheel).
. Tire Width: 281mm = 11.1"
. Tire Diameter: 732mm = 28.8"
. Capacity: 1,279 pounds
Metzeler ME880 Radial 300/40VR18-BW.
. Tire Width: 300mm = 11.8"
. Tire Diameter: 665mm = 26.2"
. Rim Range: 10" - 10.5"
. Capacity: 1,202 pounds
. Weight of Tire: 12.50 pounds
Avon Cobra AV72 Radial 300/35VR18-BW.
. Tire Diameter: 664mm = 26.1"
. Rim Range: 10" - 11"
. Capacity: 1,201 pounds
The conversion math: (8/32" = 1/4")
5.5mm = 0.218800" which is less than 8/32"
6.0mm = 0.236220" which is less than 8/32".
6.3mm = 0.248031" which is just under 8/32".
6.5mm = 0.255905" which is just over 8/32".
6.8mm = 0.267716" which is more than 8/32".
Why?
Tire manufacturers indicate minimum tread
depth in 32nd's of an inch, or in millimeters.
Date of Update: July 2011 by ArizonaWarrior
Note: please re-verify all dimensions!
Legacy Thread: who helped with the details!
http://www.rswarrior.com/forums/13-technical-discussion/173513-warrior-rear-tire-technical-detail.html
Banned
REAR TIRE
. Tire Width: 9.41"
. Tread Depth: mm = ~5.5 mm = 7/32"
Why?
Many of us run the Michelin Pilot Road 2 in the 190 for the rear and stock size for the front. Should be on the list IMO.
Discussion Starter #5 (Edited)
Filling in the blanks for the rear tire options, is this all correct?
Michelin Road Pilot2 190/50ZR17 (73W)
. Tire Width - Static: 190mm = 7.48"
. Tire Width - In Use: 203mm = 7.99"
. Tire Diameter - Static: 622mm = 24.48"
. Tire Diameter - In Use: 636mm = 25.04"
. Tread Depth: 7.0mm (9/32") = over 1/4"
. Rim Range: 5.5" - 6.0" (6" preferred)
. Capacity: 805 pounds (365kg)
. Weight of Tire: 00.00 pounds
Michelin Road Pilot2 190/55ZR17 (75W)
. Tire Diameter - Static: 642mm = 25.28"
. Tire Diameter - In Use: 656mm = 25.83"
. Tread Depth: 5.0mm (6/32") = under 1/4"
. Capacity: 853 pounds (387kg)
Note 1:
This Michelin catalog data provides 'growth' dimensions too,
so both 'static' and 'in-use' information included above.
Note 2:
Catalog indicates these tires are for 'one-up' riding (no passenger, limited load).
Ref: http://www.michelinmotorcycle.com/pubs/fitment2012.pdf
Banned
Note 1:
Note 2:
Looks great, thanks. The lawyers rule the pits at Michelin I guess as the Shinko and other brands have similiar load limits.
Vendor
Copy and pasted from the list I posted on the original thread we were posting in started.
Michelin Pilot Road 2 190/50ZR17 (Dual Tread Compound 40%/20%40%):
. Tire Width (in use): 203mm = 7.99"
. Tire Diameter (in use): 636mm = 25.04"
. Tread Depth: 9/32"
. Rim Range: 6.00"
. Weight of Tire: Not Listed
Michelin Pilot Road 3 190/50ZR17 (Dual Tread Compound 40%/20%/40%):
. Rim Range: 6.00"
Michelin Pilot Power 2CT 190/50ZR17 (Dual Tread Compound 11%/78%/11%):
. Tire Diameter (in use): 622mm = 24.48"
. Tread Depth: 7/32"
. Rim Range: 6.00"
Michelin Pilot Power "Super Sport" 190/50ZR17 (Mono-Compound 100%)
. Rim Range: 6.00"
Michelin Power Pure "Super Sport" 190/50ZR17 (Dual Tread Compound 40%/20%/40%)
. Tread Depth: 6/32"
. Rim Range: 6.00"
Bridgestone Battlax BT-023 Sport Touring 190/50ZR17 (Dual Tread Compound)
. Tire Width: 192mm = 7.56"
. Tire Diameter: 629mm = 24.76"
. Tread Depth: Not Listed
. Rim Range: 6.00"
Bridgestone Battlax BT-021 Sport Touring 190/50ZR17 (Mono-Compound)
. Tire Width: 194mm = 7.637"
. Rim Range: 6.00"
Bridgestone Battlax BT-020 Radial 190/50ZR17 (Mono-Compound)
. Tire Width: 188mm = 7.40"
. Rim Range: 6.00"
So for a passenger with the Michelin Pilot Road 3 one should go with the 55 profile?
i haven't seen anyone else listing that as a fitment, will it fit?
Thanks!
Discussion Starter #10 (Edited)
See the note in that post above. Michelin says not for passenger duty. But yes it will
physically fit (compare to other tire heights) but might not like lowered suspensions.
Its indicated as a rider-only tire. I don't know why, notice the capacities of other tires.
Thanks!
Discussion Starter #14
Probably BUT since I didn't see where they publish the tire's actual dimensions NIGHT DRAGON , Motorcycle Tyres - PIRELLI INTERNATIONAL probably smart to call them and get the actual dimensions. Just get the data to fill-in the chart:
Pirelli Night Dragon 200/55ZR17
. Tire Width (in use): 000 mm = 0.00"
. Tire Diameter (in use): 000 mm = 00.0"
. Tread Depth: 0/00"
. Rim Range: 0.00" - 0.00"
. Capacity: 000 pounds
. Weight of Tire: 000 pounds
will a pirelli night dragon 200/55-zr 17 fit on a 2006 ?
Discussion Starter #15
Nope that's not what this thread is about. I'm not qualified to manage it. Sounds like you are tho, you should start a CT thread and manage it. It would give a place where guys running CT's could vouch for them so if a member has trouble on a CT there's members to go back to for help.
you forgot all the car tires that will fit on there
1 - 15 of 15 Posts
