1 - 12 of 12 Posts
What fender mod are you refering to? The only one I saw on his site was the rear mudflap.I have seen video of the rear fender being cut down and shortened,also I think there was one of it being sectioned and rewelded.
Discussion Starter · #5 ·
Thanks guys.After reading about the Yami eliminator kit I'm wondering if I should spend the $59 & get it.I'm guessing with Redhorse's mod you use the taillight as a light source.I asked the sheriff next door if that's legal & he said as long as it's lit up.
Has anyone that has done the Redhorse mod had any problems with breakage?
Just buy a LED plate frame and you are good to go!
This is the Yami Fender Eliminator with a Radiantz LED Plate...
I did the Redhourse chop about 2 weeks ago. It looks awesome. It was a little dark on the plate, but I added Kurikan bolt lights. They are really bright. I love the look.
I did the Redhorse mod about 3 years ago and have done about 16,000 miles and absolutely no problems. I used a Radiantz roach as a license plate light.
Discussion Starter · #12 ·
Thanks guys.
I got the Radiantz Illuminatorplate frame in chrome that Siradude used.FYI I used 10-24x1" SS oval head phillips machine screws & nylon insert acorn lock nuts to mount the frame available from Lowe's.I had some leftover 1/2L - 25/32" OD flat faucet washers that I used on my right side cover that I mounted between the plate frame & the inner fender.I used the bullet connectors from the OEM plate light & soldered those to the wires on the plate frame.It looks exactly like Siradude's pix.I bought the frame from Bikerhiway.>
http://www.bikerhiway.com/illuminator-led-license-plate-frame-p-314.html
1 - 12 of 12 Posts
