? Regarding idle
1.2K views 11 replies 5 participants last post by  Penzoil
I have recently added a thunder air kit and pcIII. The map that I have, works very well throughout RPM range. The problem is after the bike is warm and you begin to turn the throttle the rpm drops down and the bike sounds like it's going to stall. This only happens right out of first gear from a dead stop. I have tried adjusting the commander on the low and high side and had no luck. Any ideas?
Thunder air kit,AIS removed,Samson Ground pounders w/performance rings,PCIII
#8 ·
Gstarret3,
the bikes ignition must be on(engine does not need to be running) when adjusting the TP settings, even with the 9 volt adapter.
The values in the Set TP boxes will not be "0" and "100" when setting them.
You can manually set the TP by connecting the 9 volt adapter and clicking the "set TP" selection.
Warrior TP Closed 36
TP Open 194
This info came from Michael Belcher at Dynojet.
Trust it helps.
#12 ·
OK : I will apply the old school here.At idle if you twist the throttle, rpm stay up and then came down slowly (lean) or stall (rich) when you twist it? IF it has both symtoms , check for open intakes on the airbox or non filter on the box. Remember when adjusting PC as soon you touch a button(low in this case)it will adjust 2%.a fast touch =rich a slower one lean.
