Re: Canister Removal Done Correctly
Alan-
Looking at the CA versus the non-CA model the only difference appears to be the fuel canister and the extraline to the throttle body
On the non-CA models:
hose (#61)that comes off the T-fitting (#60) routes down the frameas a vent
hose (#69) comes off the roll over valve (#66) and routes down the frame as a vent
On the CA models:
hose (#77) comes off the roll over valve (#66) and routes down to the charcoal canister
The other hose for the canister (un-numbered in the picutre) routes off to the cyclinder TB (per your post)
So the method I followed basically removed the vent all together since I have the roll over valve connected to the T-fitting?
I would suspect thatnon-CA bikes that the fitting on the throttle body capped?
