1 - 7 of 7 Posts
Hi all hope all is well, I finally got to the point of getting my ignition cylinder out of my broken triple clamp, Alan told me how to get them out, thank you Alan by the way, anyway does anyone know the thread size of these bolts I need to get a couple Allen head bolts to replace the break away ones
For the reinstallation of the lockset I've used M8 x1.25p x 20mm hex head bolts for a low profile and blue thread lock!
Thanks Alan your a life saver, I have made the slot in the bolt but they don't want to come out, I don't have a vice so I will have to figure it out, they are really on there
An Impact screw driver works as will a little heat to soften the thread lock. In one case I had to drill the head off. You can also grind it off with a Dremel or equivalent.
Thangs Alanh, because it was stuck in my broken triple clamp I just got it off with a grinder, thanks so much for your help, I have also bought an impact hammer driver so this never happens again
1 - 7 of 7 Posts
